What are some other good U-joint replacement tools?
DieselSaves
Big Sky Country
For about ten years I have been using an OTC ball joint press kit for doing u-joints on drive lines. Before that we used a big vise or shop press and spacers but that usually required two people to do quickly. The OTC press is great for smaller joints but I have run across several yokes with tapered ears on them that keep me from getting a strait shot on them.
Are there any other styles of press available for doing U-joints that might be more versatile?
TinKnocker
Springboro, OH
I did them on my 97 z71 a few weekends ago. I used my 5" wilton, some sockets, and some quarters. I also used my 3 ton craftsman jack handle for a cheater on the wilton :)
Double J
Springfield, OH
I use the Tiger Tool U-joint press for removal and a just use the C-clamp to install the cups. Makes quick work for removal and have three 4WD vehicles that I can use it on.
D
DieselSaves
Big Sky Country
Apart from the cost this Snap-on kit looks like the dogs danglies http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=644058&group_ID=675665&store=uk&dir=catalog
And they do seperates of the kit !
That is really close to what I have.
I really like the look of this. One is defenitely on the list.
wafrederick
Holton,Mi
Can do it with a hammer and vice too if you don't have the tool.This way,you hit on the weld and not on the driveshaft tube.There are driveshafts you can't get the u joints out,staked in from the factory.The rear driveshaft for the 2004 to 2008 Ford F150s is one of them,you replace the whole rear driveshaft including when the center support bearing goes bad with the 2 piece driveshafts.The center support bearing is laser welded in and there is no replacement u joint listed for them.
Dale1962
central illinois
just found that out lol. carrier brg went out on my 04 f150 thought, $100 for a new one. right, try $1300
metaleltr
Western Ohio
Torch, Air hammer, C clamp,
Heat the ears, puch out with air hammer, reassemble with c clamp.
Some may disagree with the heat, but on GM with the bonded cups they need heated until the plastic oozes out, then it pops right out with an air hammer.
regguy1
On Mount Olympus with Zeus
If you use a vise do not clamp the smooth section of the yoke tube in the vise as it will nick it up and cause constant leak from trans seal, I've seen this result many times.
firebox40dash5
This is my method. Hell, half the time here in Rustland I end up torching the cross out anyway because I can't get both caps to move at once. Pop the caps out with the air hammer, I usually hammer the new ones in by hand. Then work the ears over with a BFH like they owe you money until it's smooth like butter. :D
Shadowdog500
Down the shore
I made this cradle out of a piece of box tubing to help push the caps out. I rest the T part of the universal(AKA trunnions) on the cradle and put the socket over the cap and press (or hammer) the cap into the socket opening. You can also use the open jaws of a vise as the cradle.
Here is a video using a cradle and a press.
I priced the tiger tool a few years ago and the price for the set was way too rich for me.
Chris
C96
Always just used a large vise and sockets, sometimes an air hammer if they were stubborn…..Lol, but those were the easy ones.
Shadowdog500
Down the shore
ex-x-fire
Sheboygan Falls Wi.
Yeah, I like to have the cup partially in the joint before I start driving it in. You can't do that when installing both at the same time. To much of a chance for a needle to fall.
NHBandit
East Tennessee
You mean there's other ways besides a BFH, an assortment of Chinese impact sockets to beat on and a large well made vice ? Holy hell man, I've been doing it wrong for 40 years. I have also used the OTC balljoint set though.
MattPersman
Indiana
Had luck with one tiger piece, the smaller "remover" the other one I have, the larger "remover" bent the first time I used it, forgot to try to get it warrantied and I see a basically brand new one that is bent when I open a drawer at home.
The tiger clamp cup installer is magnetic on the fixed side it is handy but sure is expensive for a c clamp
The snap on bjp1 makes quick work of many of the nylon juiced caps. The hammer method on a vise is used first quite often on easy ones.
signcrafter
So you don't have to melt the plastic goo out of the GM caps before pressing them out with the BJP1?
firebox40dash5
I'd be thoroughly impressed if that's true. I did the rear shaft joints on an '09 Dodge diesel a couple weeks ago, and the strength of that goo/fiber **** was insane... almost as insane as causing that much work & mess to save 3 seconds and $0.03 on an assembly line.
PCO6
Newmarket, Ontario
I have an old Snap-on CJ.91.C1 kit that's probably from the 60's or 70's. I lifted this pic from the internet but it shows the tool and attachments.
MattPersman
Indiana
I do not melt anything, jam the bjp1 on it crank it down, take the drive tool (I use my cordless impact) off whack the socket with a hammer a couple times, tighten more, you will hear the nylon pop no heat required I have done dozens and dozens of them this way.
I am sure someone will say I am doing it wrong, or I am a hack, or something, but I work flat rate and have done so many u joints on dodge trucks it's silly I found my method and is faster, safer and easier than heat IMO. Done plenty of GM too
signcrafter
Out of curiosity how do the factory service manuals tell you to get the ones with the plastic too out? Does the manual say to heat it out?
firebox40dash5
Are you pressing across both ears, or what? Serious question, I've actually never used "proper" tools to do a U-joint. :lol:
If it's pressing across both ears I'd hate to see what it takes to get the ears aligned again. I try to only hammer outward, they tend to distort and bind way too easy if I push inward. One of the reasons I'm pretty quick to just say F it all and torch the cross out, makes it pretty easy to just pop each cap out with the air hammer.
Heating that Dodge joint out what definitely not time-efficient, I had to heat the everloving piss out of every ear.
Double J
Springfield, OH
No it actually doesn't, just put it in a vise and press away.
DISASSEMBLY - WITH INJECTED RING
1. Place shaft yoke in vise.
2. Position U-joint press (1) with receiver (2) on propeller
shaft yoke.
3. Pressed U-joint bearing caps (1) out of shaft yoke
(2).
4. Remove lower bearing cap from shaft yoke.
MattPersman
Indiana
Yes it's just like remove u joint install new one.
Just put the threaded side with proper piece on one cap, the other open side with proper cup on other side like any u joint replacement don't try to give it the business, just get pressure on the joint itself, hit the socket with a hammer a few times good whacks it may pop then already if not tighten down some more. Don't tighten down so much you ar gonna bend the ears, I never have, I have seen some do it before you just gotta use common sense let the hammer do the work of popping not the press
Heavy tech
I have the smaller Tiger Tool press for automotive u joints and a big one for heavy truck u joints. I don't think I've torched one since I got them. But it IS possible to spread a yoke with them. The press might be rated for use with a 1" impact, but no yoke will stand that.
