What are these??
Hattrick300
Midwest
I need help to identify what these were used for, they where in my Grandpa's tool box and I have no idea what they would have been used for.
H
Hattrick300
Midwest
Trertsy, I don't think it did, but I will have to look at it again to see.
And thanks guys! I knew that they had a use but I had never seen one before.
alwaysFlOoReD
Airdrie, Alberta, Canada
How are they used?
I just recently learned about the saw set when I picked one up recently. I also have a saw vice that I didn't know what was. With the two I was able to sharpen my handsaws that were dull as butter knives. With the saw in the vice with the teeth sticking up, use a triangular file to sharpen every second tooth keeping the same angle as you go. Come back sharpening the missed teeth. NOW comes the time for the saw set...Place saw set over tooth and squeeze. the saw set "sets" the tooth at the proper angle for the kerf and makes every tooth set at the same angle. The saw set I have has a dial to change the angle of the set allowing for different thickness of kerf.
Milton Shaw
alwaysFlOReD you left out one step to get the teeth all the same length, you use a gauge and file the tops of teeth and then triangle file and saw set. Hatrack300 there is probably a tooth height gauge somewhere in the stuff you got. Looks like a small metal level but with the area where the level bulb would be it is lower than the rest of the gauge. That's where you file them.
alwaysFlOoReD
[/IMG]
[/IMG]
Sent from my XT1032 using Tapatalk
crguy
SW Washington
That's the description of a raker gauge used on crosscut saws. Handsaws don't have rakers.
The tool that used to make all the teeth the same length is called a jointer. Basically a file mounted in a holder that you run lengthwise over the ends of the teeth to even them up.
H
Hattrick300
Midwest
Thanks again guys! I have since YouTube'd these tools and now understand what they are and somewhat how to use the even though I will probably never use them.
