What Are These?
MDHANDY
Plymouth, Minnesota
Your input is appreciated. Thanks
GeorgeFromPa
there called Knock wrenchs.. some people call them striking wrenchs.. yea there for beating on
ecotec
Already identified... But, I have always heard them referred to as slugging wrenches.
colin39
Slugging or flogging wrenches, and your gunna flog em��
ecotec
Thanks gents, Are they collectible?
Not really... Do they have a brand name or logo on them? A lot of tools are collectible because of brand and age and scarcity...
Also... I have never seen slugging wrenches with a hole on the striking end. Anyone else think that is weird?
Mr. T
Central PA
I've got some in my box at work... Thing is, if you need them, you probably have them. Also, if you have a nut that big you're probably doing something industrial and most industrial facilities don't buy second hand. I can say that new they're probably in the $150-$250 range each. But like I said, I doubt there is really a second hand market for them.
Trock03
West of Houston
Anyone who has ever spent any time on a drilling rig knows them as hammer wrenches. But those don't look like any modern hammer wrench I've ever beaten on.
Those appear to be in great shape. Usually the edges of the striking end are deformed from all the abuse they take.
TC
95vette
Hello, If you ever had to put in high pressure steam valves in that use a solid metal gasket that has to be hammered till they ping you would appreciate this style of wrench. These must be an older style because today's are built a lot heavier. Jim
Art From De Leon
De Leon, Texas
The hole in the handle is to tie a length of softline so that one man can pull on the rope and keep tension on the wrench while the other man hits it with his sledgehammer.
Ralf99
S.W.Victoria, Australia
Well i'll be... The hole now makes perfect sense. In my part of Australia we generally call them "slogging wrenches" or "slogging spanners" just to be different.
Slugger being a strong hitter in Baseball, and Slogger being the same in Cricket I guess(?)
geartow
ohio / pa border on I80
While slugging wrench was my first thought,I don't see any peening on them . They are all of nice uniform size on the slugging end. I think they may be for an interchangeable head torque wrench ,and the hole is for a retaining pin . The slugging end also looks too narrow for driving,also it has no offset the one I own has off set so you don't hit your work.
geartow
They may be heads for an interchangeable head torque wrench . If they are used slugging wrenches there should be some peening present from being struck.
fatfillup
Finksburg, Md
I have seen both offset and straight slugging wrenches. One of my customers refer to them as banging wrenches.
I will say Geartow may be onto something. They don't look as heavy as the ones I have had.
eddiemeddiem
Slugging wrenches. The hole in the "handle" part is for a rope to keep it tight when striking it.
crguy
SW Washington
The heads aren't heavy enough to be slugging wrenches. Some sort of special wrench that you're not going to buy cheap and flip for a profit.
SCscoutguy
South Carolina
This is exactly what I thought they were. They appear to be interchangeable heads for a large torque wrench.
OutsideMachinist
Norfolk, VA
They are slugging wrenches. Holes could be for a lot of things like people mentioned. To lanyard them or tie them off. To run rope or nylon through it to hold it tight. Rope/nylon to pull it with a chain fall or come along etc.
dutchgray
Dorset. England.
Slugging wrenches, I have a couple German ones with ends just that size and shape, sans hole. If they were for a torque wrench they would be machined and ground to size and those aren't. They look unused but are only worth having if you have a use.
bwringer
Indianapolis
Is it a complete set?
The unused ones they may be leftovers from one or more sets. If you only need two or three sizes, it's probably cheaper to buy them in sets. Toss the sizes you can't use somewhere, and years later you have created a mystery...
