what did you learn in the garage
Lkdelta
40 mi.east of syracuse
Kind of a spin-off of "what did you do in the garage"
But this is only for the area above the shoulders:bowdown: or :headscrat
It can be:
DL Did learn
NTL Need To Learn
Both are "assisted by others/publications who know how".
N.T.F.Out. Need to figure out, can also be "the first time you solo'd" on a new process, maybe you had someone doing it before and you observed?
Me NTFOut "and first solo"...rear brake drums were making lots of noise, ended up being lots of brake dust and a few rust chips...sux getting those drums off when you can't see the adjuster.
Kilo70
DL- Dont use Cheap Jackstands !(unless you have a death wish)
Skysurfer
One of my first lessons, when I was around eight, was don't try to find out what's inside of a D-cell battery by taking it apart with an icepick. I rammed the tool right through the skin between my thumb and index finger and pinned my hand to the workbench.
wolflrv
Savannah, TN
DL- How to completely tear down a motorcycle for restoration.
NTL- How to put said motorcycle back together again, once I have the funds accumulated...LOL!
BrokewrenchLS1
WV
DL - When using spring compressors, wrapping them in something - a rope, ratchet strap, whatever - is always a good thing. I'd have lost half my face this afternoon if I hadn't grabbed an old ratchet strap and wound it around the compressors and spring.
HarleyR
Huntersville NC
DL- Never hit a piece of steel bar with a hammer out of frustration... it laughs back at you by smacking you across the face...
Will67
Hell's half acre
NTFO why every time I need to use a string trimmer in a hurry that is the time it won't start with one or two pulls. I swear it knows I am in a rush and refuses to start until I pull spark plug and check to see that it is ok
koditten
Midland, Michigan
I learned that normal passage of time does not apply in the shop. Wheather I'm doing a job I enjoy or one that is kicking my ***, time goes by at 2-3x the rate of normal. Anyone know why this happens? All my buddys say the same thing. I can't count the time that I would hear the birds chirping and the sun was coming up.
darkk
Willimantic, Ct.
Hitting .22 cal bullets with a 4 lb hammer is ok if you hide behind your tool box. Hitting a .38 cal bullet is really really really stupid no matter where you hide. It seems to know where you are hiding. Even if it didn't find you, the noise is deafening!
Big Top GT
Coral Springs, Florida
DL: Just because the coil over spring looks small, it still stores enough potential energy to remove the tip of your finger when you wiggle it so it seats it properly and it actually moves.
I bled for what felt like a month. :D
A1an
Tampa, FL
DL and continue to learn how to keep an 80's watercooled 8v Volkswagen running.
NTL - welding, woodworking, metal fabrication, beer brewing
brats.n.harleys
Portage, IN
dl 0-2 beers- pinstriping is fun, and can get good results
2-10 beers- pinstriping is fun and looks great, until the morning when your sanding it off
Keep
Oshawa, Ontario
DL - no matter the part, when you drop it, it will find your toe. Then it will roll to the farthest part of the shop and hide.
DL - When working on your project, cover the exposed wheel studs with lug nuts or they will rip your leg up when you least expect it.
I also agree with the shop time flying by.
L
Lkdelta
It can be:
DL Did learn
NTL Need To Learn
I see the "Do in the garage" and "Do to the garage" threads have been busy the past few days..so, anything new?
DL Did learn
NTL need to learn
NTFO...need to figure out
Bronson
Texas panhandle
DL- The expensive carb cleaner, and the cheap carb cleaner both burn the same when You squirt yourself in the eye. I didnt learn this the first time, I had to do it twice, to make sure.:sad:
Macgyver_ga
Canton, GA
DL - When I was 16 first wrenching on cars, I learned to ALWAYS USE JACKSTANDS AND NEVER USE A FACTORY SCISSOR JACK to lift a vehicle. No one was hurt, however a friend of mine came within a second of losing his leg. He pulled it out from under the falling car in just the knick of time. 2 broken scissor jacks later, you have to get creative to lift a vehicle with no wheels on it resting on the brake rotors off the ground.
DL - The right tool for the job makes things a whole lot easier.
DL - You can never have enough telescoping magnetic tools. The bolt will fall in the most inaccessible place.
NTL - putting tools back in the same place every time. For some reason I think I spend more time looking for tools that I set down somewhere a minute ago than I do working on the project.
NTL being more careful with razor blades/utility knives. For some reason so matter how many times I cut my fingers, I never learn my lesson.
Mr.Mix
Vermont
DL: A lot so far, including how to utilize the space you have available. Also garages built out of turn-of-the-century barn board can hold some surprises (like cool old pulleys).
sherlocktk
Orange County, CA
DL - When first organizing a garage where you first put something ends up its permamnet place
NTL-The first place you put something is not always the best place
Eagle Point
Granite Bay,California
I learned not to ride my tricycle around in the garage at a very early age. My Dad was doing a brake job on one of his cars and had the car on stands with the drum off. Here I come hauling *** on my little trike and I turned sharply in the garage flipping the trike tossing me off causing me to hit the front spindle with my eye. My Dad held his hand over my eye and my parents rushed me to the hospital. A bunch of stitches and over 50 years later my eyes are still in pretty good shape. :eyecrazy:
My buddy was trying to put a handle on a hand file so he slips the handle on the file and starts banging the file end into the wooden bench while holding the handle to drive it in further. Well, the file stuck in the bench while the handle stayed in his hand and he brings his hand back down and the sharp end of the file went through his hand.....................:willy_nil:lol_hitti:dunno:
