What do I need a Dremel© tool for?
Alexbn921
East Bay Nor Cal
Love my Dremel and use it all the time. It really is a persecution tool for small project that would be a pain other wise. With the right attachments and the flex wand it can get into almost anywhere.
Removing rust in a tight spot.
Cutting square holes in sheet metal.
Polishing.
Faster sharpening than a file.
Sanding/shaping small areas of wood/metal.
Sheet rock cutter.
Dust Devil
Right next door to hell
A Dremel with a bunch-o-bits is a must have. Renforced cutoff wheels,sanding drums,wire wheel,carbide burr are the bits I use most.
Sometimes the air cutoff wheel has a kerf that is too wide, the dremel shines then. Consider the dremel a precision die-grinder. I suggest the long flex wand too.
Best thing ever for sharpening chainsaw blades (unless you just have to have a dedicated sharpener)
