What do you protect your tools with?
ImportTuner
What are people using to protect their tools with when not in use? I am using TC-11 (www.tc-11.com) and it seems to work pretty good. Used to use WD40, but it seems to evaporate too quickly.
:bounce:
brianpgriset
Beaumont, TX
:bounce:
I heard 3-in-1 is pretty good to use. Where do you get this TC-11 at. Looks like pretty good stuff.
stupidjet
maryland
does protecting them with oil based stuff actually help? isnt your tools all oily the next use? i dont use anything and everything seems ok. actually, the ONLY thing that has surface rust are Kleins linesmen needle nose pliers which pissed me of b/c i paid a good amount for them b.c they are suppose to be good, but my craftsman ones are still perfect...even my other kleins are fine...whats up with the needle nose? actually, when i think about it, i have 2 craftsman pro wrenches and 1 snap on wrench that are showing that tiniest of rusting on the inside of the box end..small spots...
I
ImportTuner
I clean my tools after each use so there is no grease on it ... TC-11 is suppose to be available from your local ACE hardware, but I ordered my from the web site ...
MXtras
On the Right Coast
Browning .380 here and if the guy is really large, a Stevenson double barrel 12 ga. (side by side - 1 side shot, the other a slug)
Scott
kythri
Lebanon, OR
chopper103in said:
my 130# rott and a 357
Hah!
I just posted this in the "Favorite Tool" thread, but it's equally apt here:
:D
SteveU
Amsoil heavy Duty metal protector, it dries to a waxy coating that is pretty tough. Don't use it on the adjustment part of a crescent wrench or something similar as it makes it about impossible to turn. I sprayed my pipe wrench jaws with it 4 yrs ago & put them in the barn, they're still rust free. Also works good for spraying the impeller/chutes of a snowblower keeps the snow from sticking.
Uncle Buck
Kansas
I have never coated my tools with anything, I simply wipe off any excess oil or grease and put them away. Unless they are really bad I never do anything to clean out the inside of sockets either. When/if non-plated tool finishes ever start to rust I find that a few moments against the wire wheel on my bench grinder will usually clean things back up fairly well. On those occasions I do hit them with a little WD-40 or the like to guard against future corrosion.
bmwpower
No rust problems now that I have a closed-in, insulated and heated/cooled garage. I don't wipe them with anything.
I
ImportTuner
Wow, pretty fancy garage .... you could live in yours .. :)
-lecroix-
My "pea shooter" shot ... keeps my tools safe too. :bounce:
Coach James
Sandhills of North Carolina
I just wipe them off after each use and sometimes a wipedown with some WD-40. I do use Johnson's paste wax on my table saw and drill press though. Prevents rust and boards slide across the table saw a lot easier.
The first answer in my head was a gun also. My gun safe is in the garage so perhaps my tools at least feel safe.
Sidenote. I bought another top chest this week and needed drawer liner. I don't feel like paying big bucks for the stuff at HD, Lowes, Sears so I went to Big Lots. They had rolls of the same stuff: 5 feet x 12" for 90 cents, 5 feet x18 inches for $1.25.
At our Big Lots, it looks like the stockers cut open the boxes and just dump everything on the floor. Are your Big Lots the same way?
Coach
MarkH
Kansas
In the think alike category. My first thought was my daughters attack pet rabbit that roams the shop backed up by a 12 Gauge backed up by a 45 Auto. Should work.
kartracer55
You guys have a lot of time on your hands to be wiping down your tools...
Not ONE of my tools is rusting and I have never wiped them down with oil. Just use a rag and lightly wipe down your tools when they are greasy and oily. The residue should protect them on thier own.
Jim
kartracer55
I know, I usually wipe them off with a rag but I dont really coat them with out.
Certain tools I really care for (torque wrenches, air tools, Meters) but wrenches and sockets just get the heavy stuff removed and put back.
TNToy
West Tennessee
My routine?
As I use tools for a job, I place them either in my service cart, or on top of my box. If it's had a greasy hand on it, it doesn't go back into the box.
When I'm done, I soak a red shop rag in brake-kleen and wipe all of my tools down with it. Sometimes, it takes two.
That's all I ever do. I suppose if they weren't all used frequently, or had a harbor-freight quality finish, I'd worry about rust, etc. :)
eschoendorff
z28toz06 said:
Ibought some corrosion X HD today from my mac tool guy. I'll check it out tomorrow.
I have the HD and I find that it ius really too heavy for most tool applications. The regular stuff is great - much thinner. The HD is almost like a spray grease. that said, it has its place.
eschoendorff
TNToy said:
My routine?
I hardly use my tools for my profession, but I have my own routine too... any tool that i use for a project gets placed on a large aluminum baking sheet and gets cleaned and wiped down before it gets put away. It's strangly therepeutic.
mulepackin
Montana
As I use my tools on a project, they get placed into the hand tray from a carry box so I don't loose any. Before they go into the chest they get wiped with a shop rag which has been sprayed with WD40 (it is good for that, cleans and protects). Everything is accounted for before the veh. gets moved.
