davesnothere
I use mine to make assorted batman fighting sounds while forcing uncooperative items into, and out of, their homes.
Are those knockoffs reverse thread?![]()
Lol.
I'm an auto tech and I have hard and soft face dead blows and I use them for everything. Since I bought some SO ball peen dead blows I haven't picked up my old craftsman sledge hammer. Then I have a big soft dead blow for breaking loose wheels that are stuck on.
SO dead blow ball peens are my favorite too.
As far as the stuck wheel thing goes, try using a prybar instead. Grab a solid spot on the subframe with the tip, and pry against the rim. The wheel will come off more predictably, and you won't be trying to catch it before it either lands on it's face or rolls into another vehicle.![]()
I usually leave 2-3 lugnuts on but have them loosened as much as possible.
No rim falling off and no scratching of the rim do to prying.
If you take two identical weight hammers, one being a standard ball pein and the other being a dead blow style and swing them with the same amount of energy and then measured the force applied to the contact point you will see that the dead blow applies more force.
There are wheels we get in the shop that we have to heat the face of the wheel with a map gas torch while hitting it with a sledge hammer (dead blow or solid) to pop the wheel off.
Can someone explain to me why you'd want hard-faced dead blows? What applications are you using the dead blow ball peins in?
I have a 5' long pry bar, (not really a pry bar but a solid piece of metal rod that i use as a pry bar when needed) pry against the wheel and subframe.. It takes a lot less effort to get the wheel off that way. I live in MN and NEVER have had to heat up a wheel to get it off, thats pretty ridiculous.. Every once in a while I will take the pry bar on one side and have someone else hit the wheel with a dead blow on the other, but thats pretty rare also
Are you using the round end? Or are the only metal faced dead blows in a ball pein variety?
I thought the round end is the pein end, not the flat (ball pein, cross pein, etc.) ??
peen/pein
a wedgelike, spherical, or other striking end of a hammer head opposite the face.
peen/pein
I use soft face DB's on soft materials (rubber, plastic, wood, sheet metal) and use hard face DB on hard items, especially steel items with edges or rough surfaces because those items can mare up the face of a soft face hammer. Once that soft face gets cut up, it can then start leaving marks on softer items.Can someone explain to me why you'd want hard-faced dead blows? What applications are you using the dead blow ball peins in?
When it absolutely has to move, here's the one:
http://buy1.snapon.com/catalog/item.asp?tool=all&item_ID=635007&group_ID=675295&store=snapon-store
Question - those sold in the UK/Europe have a safety lanyard shackle on the end of the handle. Since I don't work on an oil rig and am not concerned with dropping it in the ocean, is it mostly handy as a hanging hook?
•Hammer handles are fitted with a special stainless steel shackle to which a safety lanyard can be attached.
•Dead Blow Sledge Hammers deliver sustained impact and maximum striking force with almost no rebound.
•Free-flowing shot in head canister improves dead blow action and reduces rebound.
•Composite handle shank with steel core improves hammer balance while defusing shock.
•Ribbed, textured grip with energy absorbing microcellular material enhances comfort and reduces vibration.
•Hammers are encased in a tough, non-sparking, chemical resistant, moulded urethane covering.
jack vines
