What extractors work the best?
knocker
Peoria, Az
So I’m just about done with school at which I’m in a manufacture program and I’m going to start my career at a dealer. I have been working on building my tool box up. I have been ordering mainly SO since I get such a great discount and there’s a corporate rep here four days a week so he’s always here to take my money. I just ordered the SO TDM117A metric only tap and die set and would like to know what’s the best type of extractors to compliment that set. Thanks guys
larry_g
oregon
The best set is the one you don't have to use! On that note since I started using lefthanded drill bits to remove broken studs I have only had to use an extractor a couple of times. So whatever extractor you get drill the hole with a lefthanded bit and you'll find a lot of times the extractor is not necessary. Better if you get the screwmachine length bits, shorties.
lg
no neat sig line
wafrederick
Holton,Mi
The straight fluted extractors work great,they don't expand the broken piece of a bolt or screw.The spirals tend to do this a lot,expand the fastner and can be a real pita.
K
knocker
Peoria, Az
I totally forgot about left-handed drill bits, I have used them before when I used to work on automatic doors and they are defiantly a time saver. I also have been looking at drill index’s so I guess I should add left-handed bits to the list. On another note I’m also curious about drills, what’s my best option as a new mech, pneumatic or electric drill?
srmofo
SW ohio
The trick is to not apply too much force, Youre already in a hairy situation and breaking off an extractor in a freshly drilled hole is enough to send anyone over the edge. If you ever find yourself frustrated with a broken bolt, just walk away and find something else to do.
GeorgiaHybrid
Extreme NW Georgia
The trick is to not apply too much force, Youre already in a hairy situation and breaking off an extractor in a freshly drilled hole is enough to send anyone over the edge. If you ever find yourself frustrated with a broken bolt, just walk away and find someone else to do it.
Fixed it for you....
hammergodthor
Here's my 2 cents:
Snap on:http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=10516&group_ID=1258&store=snapon-store&dir=catalog
I like that they're slightly springy, so they flex to warn you instead of just breaking without warning.
