What Have I got? Could it be?...Peter Wright Anvil
BFBOB
I bought this anvil about 30 years ago for no better reason than I wanted it. I told the tale of its purchase here already so won't repeat it now. I hardly ever used it, and it sat in a dark corner of the garage commiserating with my also seldom-used brake. Today, I needed to bend some sheet metal, so dug the brake out. In the years since I last used/looked at the anvil, I've done some reading, mostly here, and learned a thing or two. As I excavated my way to it, I became curious as to whether it had any markings. I had never even known to look for them until recently thanks the the GJ. I sort of remembered that it had a kind of slender, swoopy look, like ... no, I dare not say it.
So I pulled it out into the light and indeed found some markings. They're faint, rusted, but at least somewhat visible. I took the best pictures I could with oblique light, and they show up fairly well. So, what does the collective wisdom of the Garage Journal say? Is it? Could it be? Did I score and not even know it??? :drool:
In addition to the Hardy and Pritchel holes, there are two holes down on the sides, one under the horn and one under the heel. They're something like 3 inches deep and tapered to a point, kind of like an obelisk. I've never seen holes like this - what are they? I weighed it at 135 lbs when I got it home, but if I'm reading the marks correctly, it's supposed to be 130. (112+18?) It measures 24 1/4" from heel to horn.
And I'm also curious as to the age of the beast. Any markings that may have been on the bottom are long gone. It's heavily rusted, and frankly the whole thing looks to me like it spent some time underground.
Any info will be greatly appreciated!
BFBOB
Re: What Have I got? Could it be?...
Yee hah!
The way my luck usually runs the few legible letters would be part of some other name. I guess now I'll have to keep it up off that damp floor.
And, of course, decide what to do with it. Scrub brush and dish soap? Electrolysis? Wire brush? Sand/grind smooth and polish? (just kidding about that last one)
Jarhead0408
Who knows?
Words cannot describe how lucky you got on that deal......
Congrats man.
kawtoy
If you are not careful it is going to rust away in 600-900 years :)
BFBOB
Thanks, folks!
I was pretty sure it's a Peter Wright. Oddly, the markings show up better in the pictures than in real life. BigCaddy, now that you mention it, I do recall the term "mouse hole". Have to do a little more research to see what they're for.
I'm really intrigued by the thought it could be over 150 years old. What other angles of pictures and measurements would be helpful in determining its age? I expect I can find the time during which they were produced easily enough, but details could be tougher.
I think for the first step in "restoration" I'll just go over it with a nylon scrub brush and compressed air - not try any serious de-rusting.
Yeah, lucky sure describes it. I knew at the time that $5 was cheap, but had no idea that was a fraction of its scrap value.:eyecrazy:
BFBOB
I didn't buy it to sell, but now that I know it's a Peter Wright of course I'm curious as to its value. It has some condition issues. The face is pretty swaybacked and has some edge chips. It has a nice, clear ring out on the heel, but less so over the middle, which hurts its working value. The rust wouldn't be a problem for a working anvil, but I expect hurts any collector value it might have. The rust is bad enough it has completely obliterated the "Peter". I carefully wirebrushed it - by hand with a cup wheel and a scrubbing motion so I haven't left any scratch patterns. That brought out the markings much better, but failed to reveal a trace of "Peter". I'll post some more pictures later.
From what I've seen in today's market, I expect it would be in the $300 range, but as I said, it's not for sale. I'd be interested in others' opinions.
Some pix, showing the swayback in the face and the one fairly major chip. It rings brightly out on the heel, but less so over the middle. An hour or so of internet searching failed to turn up much solid information on dates-pretty much generalities like mid 19th to early 20th century. One detail is that the lack of the stamping "England" places it pre - 1910 or pre-1891 depending on which source you believe. I did find out about the square holes below the horn and heel. They're for handling during manufacturing, via really heavy duty tongs. I expected more info on a well known brand like this. Oh, well, it's a good excuse to invest in a copy of "Anvils In America".
BFBOB
posted some more pix
ZRH`
It's very well used. I wouldnt buy it to use, it needs a new work surface welded on. Fairly large project but it can be done by any blacksmith.
If youre interested in this stuff The Modern Blacksmith by Alexander Weygers is a great source. He was a machinist in the Dutch Navy in WW2.
Antique value is whatever someone will pay for it, and it makes a nice conversation pieces.
ADSR
In my area, that would sell for 450+
Kirbot
New Jersey
Would getting the top re-ground be an option?
I imagine you couldn't take out the worst imperfections, but it might at least flatten out.
partsboyjimmy
Kansascity Mo.
Depending on how the repair is made you should be able to get $450-$550. If you were to sell it. Basically whether its capped or completely welded.
