What is it - Allen wrench like sockets
fourjeepin
Atlanta, GA
Just when you think you have seen it all, I found these in the set I got from my grandfather. He passed in 1989 and was a farmer/rancher if that helps any. Like most of his tools, engraved with his initials JHG
Junkdrawer Dog
LV NV
I used to see a lot of clutch head screws used on campers and mobile homes in the 60s through 1980s. Haven't seen any for a while now.
daw53
John Deere 2 cylinder tractors used clutch head bolts and screws.
Bogie1632
Southeastern Wisconsin
I believe those types were also commonly called a "bow tie" driver bits. Haven't seen any in a while but we still had some old equipment when I enlisted in the late '90s that used them.
V/R
Bogie
Mechanical Noise
Southeast of O'Hare
There's a couple of kinds of clutch head screws. Some have a round center section which your bits are suited to. The other kind is more like a X shape without the round section.
lardy1
Nobody liked clutch head. I was one that did. The bits were quite fragile but the screw drive sockets are incredibly forgiving. 30 years later you can still get a bite on them.
Mick56
Janesville Wisconsin
A few years ago I had a shop vac that was held together with them. Don't remember what brand it was, but I took it apart to repair the switch..
maydaymike
Chevy pickups used clutch head screws through the early 60s. My 60 had some, but my 66 did not.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Mechanical Noise
Southeast of O'Hare
Back in 1978, I needed to get the camshaft thrust plate off my 63 Galaxie's 289 and there were the clutch head screws. Damn! I was pleased to see the local hardware store guy had a bin of clutch head screwdrivers. All priced very reasonably. Had anyone visited this corner of the store since 1970?
"No, I need only one. Sorry."
That clutch head screwdriver has come in handy several times since I did a ring and bearing job on the 289. Most recently as a pusher to bench bleed a master cylinder. But neither one of us have come across another similar clutch head screw in the last 40+ years.
redmondjp
Redmond, WA
My '41 Chevy is full of the damn things
I came here to say the same thing! I completely disassembled my 1941 Special Deluxe in high school, and the only place that I remember seeing them was to hold the headlight buckets into the front fenders. Had to go buy a special screwdriver ($$$ to a high school kid) to get those things out.
Sadly, that car never got put back together.
383 240z
Findley Twp. Allegheny Co.
They are all over my truck, door panels, floor plates, map/glove box. If its attached to the cab, its a clutch head.
