What is it?
gearhead1
NC
Used in the old days to set the "rack"
Instead of an inline diesel injection pump, it could also be for a rotary, such as a Bosch VE pump due to the size and length of the adapter.
Basically, timing is set on mechanical diesel fuel injection pumps with a dial indicator. The dial indicator is a plain old dial indicator for the most part, but the adapter threads into the pump for the technician to set the timing.
Look at the pics here:
https://www.google.com/search?q=bos...a=X&ei=5EEjVJfvFNauyATKgIKoDg&ved=0CAgQ_AUoAw
Also, check this out:
Forward to 1:40. He uses a different indicator, but the indicator you have goes in the same place and does the same thing.
