What is this Drill Press worth??
454ragtop
Carver, MA
Not a bad drill press as imports go, has some nice features. Around here, in the NE, probably $150-200.
HTH, Jim
zkling
What size it is? Looks almost like a 17" to 20" press. If it runs good, smooth bearings, little run out on the spindle. Nice that it has the MT2 spindle for larger bits. Looks like a pretty hefty machine.
I would probably list it at $250 and take anything over $200, depending on what it looked like in person.
Something equivalent would be ~$500 new from harborfreight
http://www.harborfreight.com/12-speed-floor-production-drill-press-39955.html
Or ~$700 from grizzly
X
XDC
Waterford, MI
good looking out guys! thanks. its been in the fam for years. ive moved it from 3 houses and have used it even less
454ragtop
Carver, MA
OP, Can you measure from the center of the chuck to the column? If !!", that's a 22" drill press, somewhat of a rare item.
Jim
Packard V8
Spokane, WA
Clean up the surface rust and throw it on craigslist for $250. Make a big deal about how this is the good old genuine made-in-Taiwan, not that cheap China HF **** ;>)
jack vines
Davefr
OR
12 speed, rack and pinion table elevation and tilt, Albrecht keyless chuck, nice big table w/o an arc of shame.
I'd clean up the surface rust with WD40 and scotch brite pads and hold out for a min. of $200.
Others may disagree with me but those early Taiwan DP's are better then new China and most older USA models because of the features I mentioned.
Trey T
Houston, TX
Looks like an industrial-type DP with t-slot table. If it works well, $300 is a fair value.
I don't know if you an find any drill press with t-slot table for under $500.
PinkLinc
Phoenix, AZ
OK I have to ask... what's an "arc of shame"? :lol_hitti
X
XDC
Waterford, MI
Jim
its only about 12"
I am the mechanic in the family. I never use it but i know the second i sell it ill need it. now i am rethinking getting rid of it... just getting tired of moving it from corner to corner.
zkling
"Arc of shame" Is when an incompetent operator drills through the workpiece into the table, not the center hole. Since the table pivots around a central axis (the column) it creates an arc pattern of holes in the table.
Example, last photo
http://www.garagejournal.com/forum/showthread.php?t=125627
Check the chuck to see if there are any manufacture marking on it. If it indeed is an albrecht chuck, that alone is a high dollar item. However it doesn't look like it from the pic.
its only about 12"
Are you sure on the measurement? It looks like it would be much larger than 12", just based on the table size and overall heft.
A drill press is a very handy tool. Probably one of the last I would part with. While yours it not a top American machine it is a very nice off shore brand. 150 up to ~3000 RPM with that large table and MT2 spindle are really nice features only found on high end drill presses. Remember "A bird in the hand is worth two in the bush"
454ragtop
Carver, MA
its only about 12"
The swing of a drill press is 2X the distance from the center of the chuck to the column, so this is more than likely a 22" swing drill press. If you even think you may need a drill press at some point, suggest you hold on to it, rather than let some CL buyer beat you up for $100. While it's no Clausing, it is superior to most any drill press with a swing smaller than 17", which would be MOST Craftsman, Delta/Rockwell, Walker Turner, etc.
Jim
Mohawk Dave
SoCal
its only about 12"
EDIT: somehow I missed 454Ragtops post above mine...but anyway
A DP is measured from the center of chuck to closest part of column(throat). Times throat # by 2 and you have your DP inch#.
So a small 8" DP has 4" from center of chuck to column. Looks as yours may have 11", making it a 22" DP.....and I saw **-22 on your sticker somewhere.
So, if that is a 22"DP, that's pretty dang big. And it looks it.
(BTW, I think the way DPs are measured is STUPID! Just call it a 4"DP, not an 8"DP.)
