What is this for?
tonyprovo723
A used tool near by has trays of sockets and I found this one. What is it for? It is a 16 mm 12 point craftsman deep socket #44421 made in USA "G". It has a plastic insert which is pinned in place. The 12 point end of the socket is ground a bit to the 12 points are square to the end and the exterior is beveled a bit. There is maybe 1/8" of depth of the points to grab anything. This was nicely fabricated, no extra grinding marks and seems to have had minimal use.
Thanks for any ideas.
Sent from my SM-G965U using The Garage Journal mobile app
LXCam
Well that's the ever elusive 16mm beveled edge pinned bush jam nut starter.
BFBOB
Starting a nut onto a bolt with a long reveal - longer than a shallow socket but shorter than a deep - you try to start it but the nut just slides up into the socket, doesn't bite. Too many obstructions to reach with your hand.
Think spark plug socket - rubber grip to hold plug
... or so it seems to me.
BFBOB
wild guess here. it's to remove the nuts on volume/balance/bass controls also known as pots
WINNER!:beer:
Extra-thin nuts, want to stay proud of the panel so edges of the socket don't scratch it!
FigureItOut
Bentonville AR
WINNER![emoji481]
Are you sure about that? I don't know that I've ever seen any kind of panel mount knob that big. I usually use a pliers wrench on them, very carefully. It seems like even the big 100 watt pot I have only uses like an 8mm nut.
Sent from my SAMSUNG-SM-G930AZ using Tapatalk
BFBOB
Oops - right, normal sizes are shaft 1/4", barrel 3/8, nut 1/2 (or mm equiv.) A quick peek in the boneyard- the only nuts in the 16mm neighborhood were for fuse holders, and since they go on the back, who cares?
Next guess...
T
tonyprovo723
Talk about an emotional rollercoaster. I was excited to have an answer which seems quite plausible in less time than it took me to type my question. Only to have it denied.
Based on this concept, I Google Bezel Nut and it assumed 16 mm.
