What is this joint/technique?
vavet
Ashland, VA
I recall reading about a woodworking technique a while ago that was simple in technique because all cuts were done on the table saw. The blade height and fence position never moved
One piece had a dado cut in it and the other had a tenon that fit into that dado. I think it was intended for a 90 degree joint, like a drawer box, but I’m not certain about that,
Are you familiar with this technique? Does it have a name?
Iirc, it looks something like what I drew below.
topcok88
Locking Rabbet Drawer Joint
MJO
Years ago I made a hanging TV cabinet/shelf, I thought I invented a new wood joint, the one you drew, turns out it's been around a long time.
MoonRise
Rabbet and dado joint.
Not a "tenon", as that would be the 'finger' in the middle/center of the one piece (or slightly offset from the middle/center). Make the cut(s) so that the 'finger' is on the 'edge' and you then have a "rabbet".
The "dado" is the 'groove' cut on the other piece.
Check out the "rabbeted dado joint" here:
http://blog.carbideprocessors.com/woodworking-tools-and-supplies/woodworking-joints/
Or look here, Figure #113
https://www.gutenberg.org/files/21531/21531-h/21531-h.htm
Or how about here:
https://sawdustgirl.com/locking-rabbet-drawer-joint/
Or here (go to 0:28 and see the same joint as you sketched)
Or here:
Or here:
Or here:
https://www.woodmagazine.com/woodworking-tips/techniques/joinery/lock-rabbet-drawer-joints
Or here:
https://www.woodworkersjournal.com/rabbet-dado-corner-joints/
Or here:
https://www.rockler.com/learn/how-to-cut-four-rabbet-casework-joints-with-a-table-saw
Slight variation:
https://www.woodcraft.com/media/W1s...g-Drawer-Joint_FINAL.pdf?sha=448227181181ca5d
You get the idea by now. :lol:
Vahispd
SE VA
Yes, I saw this video for the Quarter Quarter Quarter system a few months ago. Interesting to see different names or "techniques" for the same thing.
