What is this?
The Cobbler
I would check with adt to see if it's connected. it may be monitored and if you mess with it & set it off.... well at least you'll know then
is the panel accesible or do they have it locked? you could open it up & see if it's wired in maybe
T
thomasmessi
US
It's locked I don't think I have the keys, but I feel it's weird the owner shouldn't have the keys.. Why.. Smh..
Sent from my ONEPLUS A5010 using The Garage Journal mobile app
CraigStu
Blacksburg, Va
Smoke detectors in Md and Va are required by code to be hardwired for power. That way they always have power because there are no batteries to go dead.
OCD
Edmonton, Ab. Canada
Is heat detector still needed nowadays? Can I replace it with smoke & carbon detector? This is in my garage with a water heater in the Attic of the garage..
I went with the heat detector, because a smoke & carbon detector would be going off in my garage whenever I work in it or started my car...
Stuart in MN
Minneapolis
If it's still connected to some sort of alarm, leave it in place. As mentioned, smoke detectors can have false alarms from car exhaust (or potentially from the dust and dirt that gets generated in a garage when working on projects.)
cderalow
Potomac, MD
Even hard wired detectors have batteries they are more of back up batteries. Incase the house looses power.
certainly not a requirement where I live (local FD will come install battery ones and replace them annually if requested by disabled/elderly folks)
Requirement is that you have them, preference is for hard wired, though mine are all battery operated (Nest protects).
