wcemail
This machine has a cutter that is turned by a hand crank. Still retains sharp edge. I believe whatever is being shaved or cut is fed through the side. It may just shave or cut the end of "whatever" is being shaved or cut because the crank handle would interfere with the feed through unless the material is flexible. Also, looking at how it would mount to a bench, I believe it may be mounted on the end of a bench and the operator would stand in the front. Any and all help is appreciated.
Thank you.
Thank you.
