What is your favorite drillpress accessory?
Thumper68
Duluth MN
I got this many years ago and have found it to be the most useful accessory.
I need to pull it apart and clean it and adjust the gibbs. I like this one better than some of the others since it actually has the post to mount not the bolt on type that always seem to loosen up.
I just did a search and it seems that AMT does not exist anymore.
zcbauer89
NW OH
I would have to agree with you, my drill press vise is my favorite and most used drill press accessory.
404
Mass
Twin Foot pedal to start the drill forward or reverse.
Shadowdog500
Down the shore
My favorite drill press accessory would be Drill bits! :D
In all seriousness, I had one of the HF versions of that X-y vise and liked it.
The biggest thing I keep around a drill press is pieces of wood for bracing the part, and hold downs for securing the part. A drill press vise also comes in handy.
Chris
Davefr
OR
#1 Albrecht chuck - old fashioned key chucks should have been discontinued years ago.
#2 Magnetic/flex arm work light
#3 Turntable/storage carousel
#4 Link Belt (not shown)
T
Thumper68
Duluth MN
#1 Albrecht chuck - old fashioned key chucks should have been discontinued years ago.#2 Magnetic/flex arm work light
QUOTE]
I am planning on ordering one of these, so much easier when doing multiple operations.
Key-bak chuck key holder, so I stop losing the dang chuck key.
This is a real life saver, no more dropped chuck key in to the pile of oily shavings on the floor.
zkling
Center punch
Center drill
Basic drill press vise
Chart or knowledge of proper feeds and speeds
AnEv942
Central Coast Ca
6" cross slide vise definitely 1# of accessories, rarely is mine removed.
The center post interesting, never seen one on vise. We did something similar on friends dp, his table had a large hole, no Tbolt rails/slots (odd dp) so we mounted vise to plate, welded 1" bolt to go thru table, made a LARGE wing nut.
#2 rewired DP so I can use on/off switch or foot pedal. Pedal is nice.
#3 small oil can holder, (mine has an oiler but dont use often, then the table with drain and catch can is invaluable)
#4 the accessory table, now, similar to Davefrs, handy but almost as much in the way. The way it mounted limited its ability to rotate out of the way, had to loosen to rotate DP table (and height rail). I finally broke the plastic column mount. Fixed now it rotates out of the way and mounted above height rail ring.
#5 adding flexible light in front, DPs light in head-behind quill was always drilling in its shadow.
gol4
Nebraska
My delta bench top has a laser sight on it. Line up the cross hairs and there you go. Of course I never use it. But it sure looks cool.
Mortise chisels are actually my favorite accessory.
