What is your preferred vice lube method?
Jacobson
Vice was decades dry.
I just poured some motor oil onto the threads.
What do you do?
isb cornbinder
I use a dry lube spray. No grease. I have a handed down vice over 100 years old. It was never insulted with grease.
Steve_P
High moly grease is the best for this. Loctite sells a moly paste.
PBCampbell
WV
So just out of curiosity what do you think they used when it was made over 100 years ago? Dry lube wasn't exactly common in the early 1900's.
Wax most likely. Less likely to grab onto metal fines from cutting/filing metal and ruining that threaded interface. Dry lube would be a good modern alternative. Vises with a shielded screw don't need these type of considerations.
senlow
Wheat Ridge, Colorado
I use Molykote GN on enclosed pressure screws. Any extreme pressure grease will work.
For exposed screws, I use Dupont Chain-Saver. It's a wax lubricant, with teflon. This also works well on the sliding parts.
isb cornbinder
Graphite was mined at the National Graphite Mine, Graphite, Monteagle Township, near Bancroft. The mine operated from 1912 to 1919.
Graphite mining and use dates back to 500BC.
Putting fine graphite into a liquid and spraying it from a rattle can likely dates back to the 1950s.
German miners from Keswick in the early sixteenth century had made more progress mining the graphite from this site at Plumbago Mine, Borrowdale, England.
Graphite has been in common use for about 2700 years.
Chris Christiansen
Kansas City, Kansas
I use anti-seize on the stationary, large (covered thread) type vises. Cleanup is horrible, should anti-seize go somewhere unwanted.
Fluid Film on smaller vises and tools that I restore, typically items that I handle or move around easily. Cleanup of Fluid Film just wipes up easily. The links below are the actual products that I use. I like to apply with a brush. The sprays tend to go everywhere for me, so generally, I tend to avoid the sprays.
Permatex anti-seize
Fluid Film lube and protectant
Nutria
Eastern Sierra
I've used a lot of different stuff, but lately I've been experimenting with SlipKote Chuck-Eez power chuck lube. It's designed for use with power chucks under very high pressure, so it seems like a good fit for vises. I think that the lube has some graphite as a component. Seems to work well.
PoorUB
Fargo, ND
Vise lube? What ever oil drips from what ever part is clamped in it. Maybe some cutting oil from time to time.
I have had the same vise for 40 years and never lubed it intentionally.
Shiftless
East Bay SFO
IMHO, it’s a good idea to lube a vise with something…anything… to prevent this from happening.
Personally, I use Mobil One red grease. Sometimes 3 in 1.
This is a picture that fellow GJ member Broadie posted in his new thread about wear on a Wilton machinist vise that he recently acquired. This shows SERIOUS wear no doubt from heavy use and inadequate or no lubrication.
G-ManBart
The only vice I have left is having a glass of red wine after dinner, but on my vises I used green trailer axle bearing grease. It's more than enough for lubrication purposes, repels water and cleans up easily.
wrenchr
Coke is my last vice. the soda of course. :)
Chris Christiansen
Kansas City, Kansas
Just some more thoughts:
There are different kinds of sliding parts on a vise. The sliding parts between the larger surfaces, such as between the moveable sliding jaw and the base could be "way oil" Mobil Vactra Way Oil or typical multipurpose grease such as Mobilgrease EP series. And the threaded screw, collar and screw nut could be a lubricant designed specifically for threads. Thread lube (anti-seize)
My point is this. Lubricants are formulated for a variety of service enviroments. You can read up on the vise manufacturer to see is a lube is recommended. I doubt most vise mfg even mention lubricants, (my nice new Yost does not) but a practical user like you and me, can read the lubricant product data sheets and review the recommendations for what kind of applications the lube is typically used for. All my old vises, naturally are antiques and recommendations are unknown or information would be outdated. Dry lubes for woodworking vises should be considered as well, especially in the wood shop.
As always, any lubricant is better than none. Where things get tricky is when the parts are rotating fast and then sling lubricants off the parts or operate in extreme service environment (corrosion). [Ask me about my lube fiasco with my 3 jaw lathe chuck!] Anyway, with a typical stationary bench vise, I use thread lubricant on the threaded portions and general purpose grease on other sliding portions.
Just my two cents worth... :) And your vise will be thrilled that you provided ANY lubricant!
lardy1
I have two old Craftsman (USA) vises I got at auction. I disassembled them and cleaned everything thoroughly then I believe I used SuperLube. I put a couple coats of Flood Penetrol on them and they haven't stopped working. In hindsight, grease is probably not a good idea but they're working.
Komet
WA
Hosed mine down with penetrating oil initially to wash the grime and rust off. Once it was freed up, I put wheel bearing grease on the screw and big blocky bit that hangs out the back. It works good, but I reckon you fellers are right about the grease attracting debris which is inevitable in the vise environment, might consider a dry lube in the future.
anndel
Hawaii, USA
Mission silicone paste on the threads and WD-40 Silicone spray in other moving parts.
