What lock type?
bluedog225
Texas
I picked up a couple of very heavy steel doors at habitat Restore. They’re only 6’2” or so tall. And about 3 feet wide. They came with an inch and a quarter thick window insert that says it’s fire rated.
I guess it’s for some sort of industrial or a commercial application where a short door is ok.
Anyway, does anybody care to speculate about what type of lock I could put on this thing?
I’m going to use it as a man door for my shipping container. To keep the air conditioning in and provide another layer of security. I can always secure a plate and put a hasp/puck lock on it. But if there is a more elegant solution, I’d like to give that a shot.
Thanks
PCustoms
VT
That seems more likely to be a good idea. Measuring correctly or mortise lock seems challenging. Thanks
I grabbed some steel doors for a shed a few years ago.
I added 1 deadbolt and used self tapping screws for a couple big metal pulls. Cheap and as secure as the door frame.
no704
you'll find Mortise locks to fit that are very expensive . if you're not a welder, I would get a door wrap & install std deadbolt and passage set
1774809740707.pngBottom
This is most likely your best solution. Commercial mortice locks come in hundreds of different configurations and are expensive.
Milton Shaw
Home Depot carries a lock reinforcer that several sizes are available to install over the door and opening and mount a regular door handle or dead bolt lock and may be what you are looking for. Somewhere around $15 each and available in different finishes, I used one on a used fire door for my garage.
