What Machine Tools Do You Have?
c7z06
Edgewater, MD
We've had the opportunity to see vises, tool boxes, old tools, etc. What machine tools do you have (lathes, mills, drill presses, band saws, etc.)? Be sure to include vintage machinery, restored or otherwise. The more photos, the better!
jclem40c
Liberty NY
South Bend 9in lathe, 13in lathe, horizontal mill, vertical mill, surface grinder,
shear break roll, bandsaw, drill press, belt sander, jump shear, metal band saw, power hack saw, 20 ton press.
81turbota
USA
Bridgeport 1.5 hp 2J, South Bend 10K and an old Craftsman drill press
ovilla
Plainfield, IL
AMMCO on car brake lathe, AMMCO 4000 brake lathe, Branick 7400 strut compressor, AMMCO 5060EX tire changer, AMMCO 7060EX-EH tire changer, AMMCO 1050 wheel balancer, 20 ton press, and a Lincoln 180 Mig. No this not in a professional shop. This is for personal use in my garage.
rsanter
visalia ca
Pratt&whitney lathe
South bend lathe
Emco lathe
b port mill
Brake
Shear
Drill press
Band saw (metal)
Band saw (wood)
Valve grinder
Bead roller
English wheel
Mig
TIG
Plasma table
BTL-A4
Santa Clarita
Is that a 914 in your avatar image? Do you use your tools on that?
BTL-A4
Santa Clarita
Craftsman floor drill press (from 1972)
Craftsman 12x18 lathe (from 1944)
Craftsman table saw
Craftsman bench bandsaw (wood)
Craftsman 12" wood planer
Makita portable bandsaw mounted to a Swag Offroad table (metal)
Craftsman disc/belt sander
LMS 3990 bench mill
RF-30 clone mill
I'm running out of garage for any more.
mikegt4
sw ohio
Weiler Matador lathe
Millrite milling machine
Jet drill press
swivel head bandsaw
brake
bead roller
MIG welder
shop press
A couple of 50's era Oliver track loaders, they serve as anvils, shop press and a stout workbench/mounting point for anything that I want to bend. They also serve as a metal crusher, just ask my battery charger.
ovilla
Plainfield, IL
Yes I use my tools on both of my 914’s and also the rest of my cars, as well as other friends cars. My cars only go to the shop for alignments and that’s only because I haven’t found a reasonably priced Hunter alignment machine yet.
DocsMachine
Two engine lathes, one CNC lathe, one turret lathe, two vertical mills, one horizontal mill, one CNC mill, four drill presses, two bandsaws, five welders including a spot welder, four bench grinders, two belt grinders, one surface grinder, one valve grinder, one CNC router, one CNC laser, a 40-ton press and two metal shapers.
:D
Doc.
MushCreek
Upstate South Carolina
1965 Bridgeport mill
11x32 Summit lathe
Harig 612 surface grinder
24" Kalamazoo horizontal band saw
I'm not sure what the dividing line is for 'machine tools'. I also have three bench grinders, a MIG welder, a hydraulic press, A 6x48 belt sander, a drill press, etc.
Dave455
Sussex, England
Lathes - Myford Super 7
Cowells 90
Drummond (under restoration)
Myford M7 (awaiting restoration)
Milling Machine - Centec 2
Drills - Ajax 5 speed pillar drill
Startrite 10 speed / high speed pillar drill
Jig Borer - Perrin (Swiss)
Plus a selection of other smaller stuff including a mechanical hacksaw, linisher, polisher, and my grandfathers Bridges grinder. Dread to think how old that is!
Andy FitzGibbon
American Tool Works "Pacemaker" 14 x 54 lathe
Lodge & Shipley "Patent Head" 20 x 186 lathe
Wade 8A 8 x 24 tool room lathe
Lodge & Shipley "Patent Head" 14 x 36 lathe
Kearney-Trecker No. 2H vertical mill
Cochrane-Bly "universal shaping machines" (2)
Coulter 24" openside metal planer
Prema 12" metal shaper
Federal metal planer
Pratt & Whitney 3C lathe and mill
Dreses 4 foot radial arm drill
Zewo 2 foot radial arm drill
Powermatic 87 vertical bandsaw
Kalamazoo 8x16 horizontal bandsaw
50 ton H-frame press
Plus a bunch I've had to sell over the years, because I ran out of room...
Doug Arthurs
Ontario
I'llplay
13" standard Modern lathe
Taiwanese vertical mill
Doall vertical bandsaw
Taiwanese horizontal bandsaws
Buffalo drill press
Lincoln mig welder
gas powered portable stick welder
plasma cutter
30 ton hydraulic press
Beer fridge.
Jawn
Stuck in traffic, GA
Nothing spectacular:
Grizzly 10" lathe (G0602)
HF mill/drill (the bigger green one)
Older HF (Taiwan) benchtop drill press (13spd? works slow enough for drilling steel)
bobcatdan
Kaukauna,WI
Nothing too fancy. 11" South Bend lathe, 15" Baileigh benchtop drill press, 1960's Craftsman horizontal band saw, Matco(Wisstoa) 7" bench grinder, Dayton 2" belt grinder, Nugier 50 ton press. At somepoint I want to find a Millright 2/3 size bridgeport mill and upgrade to a mitering bandsaw.
Ign
Butte Peak ND
What are you hobby guys doing with surface grinders? Just curious, I've got one that needs a bit of work but I've never actually had a need for it.
I built some 1-2-3's and a sine vise in school...that was the last I used a surface grinder....
Cryptic1911
Willimantic, CT
Bridgeport series 1 j-head w/ dro, A 1942 doall metal master bandsaw, an old ?? power hacksaw, an mk morse metal devil metal dry cut chop saw, baldor belt grinder, a couple bench grinders, dewalt portaband in a swag offroad stand, an old pexto finger brake and a rogue fab tubing bender and versa-notcher
Had a 1904 pratt & whitney lathe, but sold it. Also used to have a 1939 delta 16" bandsaw w/ the gearbox for metal cutting
matt_i
I rarely use a drill press..
I was thinking same...
although I do have a Clausing 20" dp with power feed (a 2276 maybe??)
Adcock & Shipley 1ES-G horizontal mill
K&T 307 S-12 horiztonal mill
Bridgeport, 1980s serial
Fadal VMC-15
Monarch 10EE (2 - one is my Dad's needing some work, other one runs)
Monarch CK12 x 30
Monarch EC collet lathe
Monarch 13" x 30 lathe
Mazak turning center
Harig 6x12 surf grinder
Landis OD grinder
Breda radial drill
Putnam 24 x 72 double column planer
Steptoe-Western 12" metal shaper
DoAll C5A hydraulic shuttle feed bandsaw
Wellsaw 58B horizontal saw
Kzoo 12" cold saw
Barber Colman 6-10 gear hob
Barber Colman 16-56 gear hob (although this is going to be listed)
CEC Metal Muncher 35T ironworker
Diacro 14-72 press brake
Betenbender 1/4 x 48" hydraulic shear
Enerpac 30T hyd press
Atlas/Dake #4 arbor press
various other Diacro & Tennsmith sheet & rod benders/corner notcher/finger brake
Has the shop bursting at the seams :dunno: Its been an incredible adventure so far!
Ign
Butte Peak ND
A drill press set up with a tapping head can be pretty cool...I've got a ~20" 3ph Powermatic that I keep threatening to wire up to a tiny VFD and do just this
Jawn
Oh yeah, I've got a cheapie self reversing tapping head... makes repeated tapping way too easy.
Ign
Butte Peak ND
I've always been afraid of the imports, but without good reason. I've stuck w Tapmatic even though they're $$$
C
c7z06
Edgewater, MD
I showed this in a different thread, but I set up a 10.5 amp variable speed, reversing mag drill on a drill press column to do tapping.
dutchgray
Dorset. England.
Bridgeport Series 1 BR2J2
Ajax milling machine, Bridgeport clone, 3hp, 40 taper step pulley head, 48" table, will be for sale soon as its pretty worn and my Bridgeport is a really nice example and I don't have room for two mills.
HES lathe, French 11" by 22" 4hp engine lathe
2 British 10" pedestal grinders
RJH ferret tool grinder with diamond cup wheel for carbide.
Pollard 4 spindle gang drill
5 different pillar drills in various states, mostly British 4 or 5 speeds, one Taiwan 3 pulley and a 10 speed back geared Elliott Progress.
Wicksteed 8" power hacksaw
Q&S 10" horizontal bandsaw, not running currently but will be sold when its done up as I just don't need it and it takes up a lot of space
afazz
Pittsburgh, PA
Everyone should post pictures!
I have a Jet lathe and just picked up a Bridgeport.
Joebass
Ny
Solberga 24" geared head drill press
Fosdick 20" drill press
Rockwell EFI radial geared head drill press with tapping function
Doall EFI 20" geared drill press
Bridgeport 2j various speed mill
Southbend 10x54" heavy 10 lathe
Clausing 5904 12x36" lathe
KO lee 6x12 surface grinder
Roll-in bandsaw
Marvel 81A automatic tilt frame bandsaw
50 ton iron crafter iron worker
Niagara 6 foot 10 gage mechanical shear
National 6 foot 12 gage box pan brake
Looking for a mid sized k&t or Cincinnati horizontal mill, 24" shaper, 16" monarch lathe, 100 ton or so hydraulic press brake and at least a 20" Doall vertical saw.
rmack898
Honu Grove NE Florida
American Pacemaker 14X54
Monarch 10EE
Bridgeport 2J
Brown & Sharpe #2 horizontal
Burke #4 Horizontal
South Bend 7" shaper
Ellis 1800
DoAll 16" vertical
DoAll DTR28 Radial drill
Taiwan 16 speed floor drill press
Walker Turner bench top drill press
Craftsman bench top drill press
Boyar Shultz 618 surface grinder
Import tool Grinder
Jancy Radius Master belt grinder
5'x10' CNC plasma table
Pexto stomp shear
TennSmith pan brake
Pexto slip roll
Pexto slab shear
Dake arbor press
various benders
A few Blue welding machines
nadogail
Coronado, CA
I have a Drill Press that I bought in 1977 from an ad in the back of a magazine.
A Sears Craftsman 12" Floor Saw, purchased used in 1977
6" Craftsman Joiner, purchased used in 1978
A Craftsman 14" Bandsaw, New in 1977
12" Harbor Freight Disk Sander new in 2002
6" Harbor Freight Belt Sander new in 2001
RoninB4
Under My House
What's currently in working order or even worth mentioning.
Bridgeport J head
Weiler lathe
Gorton cutter grinder
Mitsui surface grinder
Mitsue-Seiki jig borer
Miller welder (2)
cheap horizontal band saw
Jawn
Since pictures were requested, here's a potato:
G0602 lathe, old taiwan drill press, HF mill/drill. Bonus pic of an old Diehl bench grinder.
bczygan
DETROIT! Arsenal of Scrappers
Have: Some of them.
Goal: All of them!!!
Bill
Bridgeport Mill
Plasma Cutter
HF Bender
HF Pipe Bender
HF 20 ton H Press
No name Bender
Arbor Press
Oxy/Acet Set
Vertical Band-Saw
Misc. Craftsman Block Grinders (13)
Kalamazoo Belt Sander
Kalamazoo Disc Sander
Delta Drill Press
Buffalo Drill Press
Dumore Sensitive Drill Press
Camelback Drill Press
Walker Turner Drill Press
Trinco Blast Cabinet
PEXTO Shear
Lincoln Welders (4)
HF Welder
TIG Welder
South Bend Lathes (2)
Kalamazoo Horizontal Band-saws (3)
AMMCO 3000 Brake Lathe
Speedaire Air Compressor
ez-duzit
Marina del Rey
Index Super 55 knee mill
Logan 2557V 12" x 35" lathe
Vectrax 18" vertical metal bandsaw
Vectrax 7" x 12" vertical/horizontal mitering metal bandsaw
Agazzani 20" wood bandsaw
MiniMax 16" wood bandsaw
(2) Unisaw 10" table saw
Rockwell 10" contractors saw
Sears 8" tilting-table table saw
Craftsman 10" radial arm saw
Delta scroll saw
3-1/2 hp Stanley table router
General International 10" jointer
Delta 13" thickness plane
Delta shaper
Max spindle sander
Ryobi spindle sander
Performax 22/44 drum sander
State 24" disc sander
Delta belt/disc sander
Wilton belt/disc sander
Delta dust collector
Baldor carbide grinder
(2) Delta drill press
Chicago benchtop drill press
Miller Dynasty 200dx tig welder
Miller 211 mig welder
Hypertherm xp45 plasma cutter
Porter-Cable 60 gallon air compressor
Emglo air compressor
JD-Square Model 32 electro/hydraulic tube bender
50 ton Carolina hydraulic press with sheet metal brake
mikeinri
I have an old Langelier / Leach sensitive drill press (with local pedigree to Providence, RI), inherited from my Grandfather (RIP), who acquired it when his employer closed up shop in the 80s/90s (jewelry industry). Awaiting restoration...
I also have a very lightly used Jet JMD-18 mill/drill (motor dates to 2007), which I grabbed from my employer during a cleanout. Awaiting me to have time to carve out a workspace in the garage (and to run 220v power out there).
Mike
slodat
Central-ish, WA
Tree Journeyman 425 CNC mill with updated servos and controls.
Hardinge lathe with Accuslide CNC conversion. In process of installing modern control and servos.
5' x 8' import CNC router. Again with Centroid controls.
Plan is to add a slant bed CNC lathe, a nice older manual toolroom lathe, CNC plasma and a VMC.. as budget and time allow.
