What projects is everyone doing this weekend?
jake26
I am not counting the parade, fireworks, grilling and drinking.
I really want to get back to my garage makeover. My wife's honey-do list keeps trumping my garage to-do list. I started building a floor above my garage trusses since they are not rated for storage but so far I only have the center beam, header, two joists and the attic ladder installed in over a month.
Anything cool going on for the holiday weekend?
beee85
boca raton florida
i HAVE to finish putting all outlets in one circuit in the garage, then install baseboards and paint! and watch some fireworks..
red baron
I am gonna put up my dodge for sale this weekend, and start looking for a new shop space.
Hogan's Hero
The Original Oil Fields
Getting ready to pour the floor in my garage. First part will include radiant heat..then the rest of the floor will be poured. I have been waiting for a little over two years for this. :thumbup:
Wingnut65
Tampa Bay, FL
Insulating my garage door. Cleaning out stuff and organizing my shop in preparation for new RaceDeck flooring that comes next week. Finishing attic floor so stuff can be moved from garage to attic. Sleep.
Mike83
Wisconsin
Clean the efflorescence off the kitchen tile grout I installed, install the rest of the grout for the kitchen tile, sand down the cabinet doors that don't fit right, finish installing the rest of the cabinet doors, start painting baseboard and door casing, build (assemble) kitchen table and bookshelves for office. We'll see if I get half of this done.
GTO
NJ,FL
I am in the process of redoing the entire front end of my collector car.
Removed the front clip along with all steering and suspension components.I am also having the motor rebuilt.It will not be back together much before September,I'm guessing.This is a little more than a "weekend project"
yotarover
working getting my flatbed setup before i go weld it all together
frame is 4x4" square tube
deck is 1/8th" thick steel sheet
yotarover
dont mind the date stamp ; the camera doesn't understand how to stay set
lilredex
Toronto
Have a HP washer pump that has been out of commission for a few years because the discharge body (cast iron) port is cracked (from frost) and now leaks. I miss it as it is the only washer I have that handles hot water. Rather than risk splitting the (weld) I'll probably (weld) a reducing bushing (1/2 X 3/8") right in the outlet to avoid that. The outlet is 1/2" NPT now bushed down to 3/8".
Have some choices, Nickle rod with my trusty Lincoln 225AC, Braze with oxy-acetylene or my Miller 135 with silicon-bronze wire (.024")........kind of leaning towards the last one.
Not much to risk here, as another body is about the same $$$ as a whole pump, probably.
This one..........http://multipressionlc.com/en/produ...hollow-shaft/5321C-H-1-000-psi-2,20-gpm/2089/
JTSmithson
Bloomington, Minnesota
oil change on the bike, maybe the car, clean up garage after various projects being "put away" but not really put away in proper places. my garage is a warzone of landscaping and various car and household project remnants.
99SVT
if weather permits, I want to sand blast an early '50s Murray pedal car, that was my mothers when she was little, in preparation to get it powder coated. I plan on getting it back together so my 17month old daugther can play with it.
Mike83
Wisconsin
Don't tell CPSC...:lol_hitti
nate379
Palmer, AK
Finish replacing the front rad support on my WRX, weld it all up, then rehang rad, bumper, etc.
Pull trans out of one of my trucks to replace converter
Running wiring for shed
Frame floor for shed.
I will be stoked if I get all that done.
ovilla
Plainfield, IL
Not sure how much I'll get done, but here's the list so far.
Finish putting together my portable pond watering buggy. Just need to make and bolt on a platform so I can mount my pump to it. Already have 250' of hose with numerous sprinklers - all with brass quick disconnects.
Take the rotors to Pep Boys to get them turned ($15/ea) and then do a brake job on my van.
Install a LM3800 with two 902LM wall units (one by the garage doors and one by the house entry door). Need to also run a new outlet in the ceiling so both LM3800's can be plugged in.
Pressure wash the house
Stain the deck and my kids play set
Sharpen my extra mower blades and put them away.
Clean out my garage (one bay is a huge mess)
Drain and refill the hot tub
Swap out the exhaust on one of my 914's (putting in a bursch)
Get back to working on my basement
That's it for now!
katit
St. Louis, MO
epoxy paint garage floor. I really need this done because I can't setup garage untill it's all painted!
glntom
Glenwood, AR
reinforce my dirt track cars frame with 1/4" plate over rearend, Clean/go thru 4412 Holley
Change oil, plugs, set timing on dirt track car. Go out saturday night and try to put it on the front(most likely break something)
kymatt
Bluegrass State
Wax on, wax off for me. Tundra, Ram, and El Camino are overdue for the spring detailing. Ram needs probably two passes from the Porter Cable, El Camino will get one.
The wife's RX was done months ago...:headshake
eldirector
In addition to the family/holiday stuff:
- finish rewiring the charging system on the Jeep
- finally finish my solar-powered rain barrel watering system for the garden
- Cut the grass (and do a GOOD job this time)
- Change the oil in the other Jeep, and clean up the garage a bit
- install an alarm system @ my mother's house
It will be a busy 3-day weekend! We are also watching a parade, taking in a baseball game, watching/shooting fireworks, and visiting my grandmother.
BigE
Central Alabama
I've got plenty to do, but my major goal is to finish replacing rotted fascia boards on the house, paint them and clean the area behind the downspouts in preparation for new gutters. I'd like to work on my car a little this weekend, but we'll see how the house stuff goes first.
spongerich
Monroe, NY
I brought home a 72 Honda SL100 from a friend's barn that's been sitting for 10 years. It's just a little past the point of being worth restoring, so I'm planning to part it out.
This weekend's plan is to disassemble, clean, photograph and get everything ready for eBay.
If I've got time, I'm going to get my Parker vise into the electrolysis tank too.
FlashJim
Houston, TX
I took off all next week. I hope to finish painting the garage walls, build cabinets, and move the tools from the dining room back into the garage.
Other than that, I think we're going to see Twilight WhatEverTheNameIs and Knight and Day.
bobadame
Got my electrical final signed off yesterday. This weekend I'll be working on getting the water and sewer connected. Then I'll be ready for the building final. Then my wife wants to throw a party. I'll be glad to finally be done. This project has taken 2 years. I don't care for partys though.
Jazz
Newport News, VA
Possibly getting started on my nitrous system install. Had the parts on the shelf for almost 3 months now and haven't gotten around to it, partially due to the heat and preparing the car for autocross events (which don't require nitrous).
Also the garage cleanup continues and I will need to remove most of my hot tub surround to accomodate the addition we are building on the back of the current garage.
Hal
Vermont
Got ten acres of hay laid down, gonna cut more tomorrow morning, and start baling tomorrow afternoon. Some horsey type people are gonna get some added Fourth of July entertainment when I call and say " Your !@#$%!!! hay is ready, come and get it NOW!!! It won't all go down the road, there will be plenty of fun stuffing some of it in my own barns.
Of course there will probably be some emergency type machinery repair involved as well, it always seems to happen that way.
OccupantRJ
Eastern North Carolina
Thought about silver solder?
e-tek
Saskatoon, SK
Holy, between these ovilla and katit, we have MOST of my to-do list!!
That's it for now!
"Course I've got 6 weeks off before Labour Day - so I SHOULD be able to accomplish it all!!
Then, just when you think you've listed all the options....some GJ dude posts another one!
jethro29
central delaware
finish the roll cage in the pinto and mow and weedeat.honeydo wants the house powerwashed but not sure if that's gonna happen.we'll see.
mhm993
Build a new enclosure for the pool filter.
Oil/filter, dif oil, brake pads/rotors/flush, filters, alternator belt on the Miata race car.
Figure out why the spa leaks
Wire up a ceiling fan in the garage.
little d
NW Oklahoma
jack hammering the foundation footing that shouldent be there, so i can pour tue. i hurt where i didnt know you could hurt, lol.
lilredex
Toronto
Thought about that one too. But, always a but, have not had that much sucess with CI and SS. Have found it really hard to get it clean so the SS flows properly. If the body were steel it might be my first choice, then again if it were steel, I wouldn't have this problem in the first place.
Was leaning towards Brz. MIG as it will be fast yet controllable and with minimal heat. Was planning on trying it on a very small point, and if it doesn't feel right, clean it up and use the nickle rod. I know that one works but it really heats things up. Got nothing to lose, it is basically NFG anyway.
Had this pump for some thirty years and come fall a simple spin of the (electric) motor was sufficient to clear the water. Something happened (not obvious) last time I did that and there was enough retained water to crack the pump. If this works, you can be sure it will be thoroughly cleared of water.
Thanks for the interest.
Frank.
vette
Finish polishing and rebuilding tri-power set up for a cust. Lots of time spent on it.
Nighttrain
Dripping Springs, Tx
Sit in the garage and think about all those projects that everyone of you on this post is doing. Ill drink a couple of beers and think that I am glad I didn’t make a work list for this weekend because I know I would not get them done. 
Ill go buy some fire works and have fun with the kids. The family will be leaving on the 5th for a two week road trip so then I will get to the work list. I am starting to build a horse barn for the horses next weekend.
Happy 4th of July to all, fly a flag and remember what this day is about.
930dreamer
Amarillo,TX and Stinnett,TX
Try to run some black pipe for my compressed air system, Swim, grill and go to the Yes/ Peter Frampton concert in Abq, NM, kiss my wife and see fireworks. Happy 4th everyone.:)
t100
re-spray paint my rear bumper. it's a custom made, of 3/16" steel plates, weights 120lbs. I just removed it from the truck by myself, took me 2 hours. will get the old paint off with a wire wheel first, then repaint. haven't been done it for 2 years.
