What R-Value For Shop Attic?
Olympus
Missouri
Now that I have my ceiling up, I think I need to start getting an idea of what and how to insulate it with. I've read a lot of people on here say you can have it blown in for almost as much as you can do it yourself. So far, the only quote I've gotten is $850 blown in to a R19 factor. That just seems kind of expensive to me and the guy said R19 was the minimum he would recommend.
I would think I could roll in batt insulation for a lot cheaper than that. I can go up to R30 batt and do it myself for $675. My trusses are only 4" tall if that matters. I just have no idea what I should be looking at getting here.
BlackTalon
Alexandria, VA
For reference, the residential portion of the 2012 International Energy Conservation Code requires R-49 for ceiling insulation for the zones in Missouri. They allow a reduction to R-38 if the insulation stays uncompressed over the top wall plate at the eaves. The IECC is part of the IBC, and is typically the model code referenced by most states.
O
Olympus
Missouri
I'm talking about a detached shop that will be kept at a temp of about 45 when not in use and around 65 to 70 for various times when I need to work out there. I don't want to spend money unnecessarily for insulation and I wouldn't think it would be necessary to insulate to the same level as I would a residential structure that is being lived in.
Falcon67
Merkel, TX
Our min here is R-30 and I'm using roll/batt R-19 because I'm cheap and thats what was left in the budget. Works just fine. R-30 batts would pretty good IMHO.
O
Olympus
Missouri
I found a cheaper R30 batt at Lowe's and it would be $540 if I did it myself. I guess going with 30 over 19 would see a cost savings in heating over the course of a few years.
Casey69
Earth
menards will rent an insulation blower; i'm guessing HD & lowe's would too. you priced out blowing in the insulation yourself?
newhollandpuller
NW Ohio
I had 20" of blown in insulation put in mine and its r-60 and its well worth it. You'll save it back on heating bill..
theoldwizard1
SE MI
R30 would be minimum IMHO.
You can rent a blower at HD or Lowes. Blown in cellulose is usually cheaper than fiberglass.
BlackTalon
Alexandria, VA
The Code is all about energy conservation, not your comfort. I posted that just as an FYI. If you needed a permit for work you were doing you would typically be held to this.
JCByrd24
Bath, ME
True r-30 is where you see diminishing returns on your money, see link below, and this is what I would shoot for personally. But the key is achieving true r-values vice what the label says on the packaging. If you have vented attic space above your insulation you will lose a bunch to air movement through the batts due to convection. Thus energy codes usually require more in attics.
http://360homeinspect.com/index.php/r-value
James-W
Southeastern Wisconsin
For a detached garage only heated to 45 degrees except for the occasional work project, I would say R-30 would be acceptable. I wouldn't go any less than that though.
Ray-CA
San Diego CA
My wife and I installed R-30 in the ceilings and R-19 in the walls of our 28x30 garage. Ceiling height is 11-feet and it took us about 5-6 hours. Had to get in done because the sheetrockers were coming the next day.
The batt stuff is pretty easy to install.
Ray
Hop2it
Fairport ny
You buy insulation once heat very winter.I have r40 in the ceiling and r 25 in the sidewalls.I found a lot of reclaimed polyiso. Foam sheets on Craig's list and kept the cost fairly reasonable.
Doug
JonnyC
Green Bay, WI
Well I just bought R-13 batts from Menards for my drywalled attached garage ceiling with 2x4 24" OC trusses. I was going to go with blown in, but my 5/8" drywall is somewhat sagging between the trusses (although not very noticeable) and has a really shoddy tape and mud job. If I ever end up having to replace the drywall I thought it will be easier to remove and possibly reuse the batts versus blown in. I also think blown in is a pain in the *** when you need to go up there to change up wiring or anything else. My thought is something is better than nothing. Plus I can always add another perpendicular layer of unfaced batts if needed.
