What to seal work bench top with?
Double B
North Shore of Lake Erie
Just finished the new improved work bench and I am in the beginning stages of painting/sealing it up.
My reqwuirement is to seal the wood top and still have a function work bench. Functional meaning heavy duty wood/engine work on it.
I was thinking of using Thompsons water seal. Basically two coats. I don't want a varnished finish. Just want to stop the wood from sucking up all kinds of nasty oil and solvents when dripped on. I know the Thompsons will not stop the solvents and oil permently. But it should severly slow down the absorbsion factor so I can wipe up with towels when it happens.
My question is has anyone ever tried it before? How did it work out for you long term?
I don't want varnish as that is a paint. I want a wood sealer.
Stephenw
Utah
I'd use a natural drying oil, like boiled linseed or tung oil. After applying the finish, beware of spontaneous combustion of the dirty rags.
I do my dirty work in a drip pan...
GeorgiaHybrid
Extreme NW Georgia
Have you thought about a matt finish polyurethane? I can't imagine something like Thompsons doing much on a tear down bench. I have used a wipe on poly coating for places that I don't want it to look like I have a finish on the wood. It works great, doesn't take too long to do and lasts fairly well.
Buckgnarly
VT
I used varnish, nice thick layers. But I also took some steel plate to give me a "beatin'" area and used stall mat material from TSC for the rest. Nice pretty finish underneath but steel and padded useable work areas
TSC sells it by the foot, but be aware it soaks up oil like crazy.
Jack Olsen
Los Angeles
I stained my benches so they'd all be the same color. They have a few layers of marine varnish on top of that. But then I also cut some lengths of rubber carpet-protector stuff so I could use a hammer and worry a little less.
Still, they get nicked up.
This picture has everything clean and sparkling. But if you look at the Maple-topped bench at the opening of the garage, you can see all sorts of 'patina' in the surface. Benches are made for working, after all.
Oh, and if you think that's too clean to get any use, here's a snapshot of it right now.
MoonRise
Varnish.
Pretty durable, not too expensive.
Oil finish is not as durable (but certainly easier to 'touch-up, just clean-scuff-apply).
For a woodworking bench, either is probably fine.
For a metalworking/engine/machinery/lots-o-oil type of bench, I'd go more for a metal top with possible drip lips (or a metal drip pan underneath the work.
If you're only going to do 'oily' work on the bench and no wood stuff, fine and don't worry about it (other than a piece of oil-soaked wooden bench top, Keep sparks and flame away!)
But when (not if) the oil/grease/grime/gunk/crud soaks into the wooden bench, you really don't want to be doing (or trying to do) any sort of 'fine' woodworking. All the 'crud' can transfer over to your 'nice' wood pieces and raise havok with trying to put a finish on your 'masterpiece'.
YMMV. :beer:
38Chevy454
Cincinnati, OH
I used oil-based polyurethane. There are new water-based formulations, but since I expect oil and solvents, the oil-based seemed a better choice. Takes a long time to dry, so coat it and let it sit at least 24 hours. I used 2 good coats on my workbench top which is just plywood. First one soaks in quick, the second gives you the sealed top surface.
Both excellent choices !
IIRC, you need to thin about 1:1 (more for the first coat) with mineral spirits/turpentine. It will take a couple of days to dry. Multiple coats are required, but once completely dried, you will have one of the toughest, longest lasting finishes ever.
Tung oil is a much better wood preservative/waterproofer than Thompson's or anything else. It is a pain to put one (multiple coats, long drying) but it is extremely durable.
Iroc-Z
New Germany, MN
I will be sealing my with Bar Top Epoxy. I have found that Menards sells it. Comes as a two part epoxy that you pour on. Self levels and dries.
regguy1
On Mount Olympus with Zeus
How about metal over the wood? It will take punishment and last a long time.........
I have wooden bench top, I had a metal fab shop make a metal piece to finish it off...used this one commercially for over 30 years, now it's at home still going strong.
kwright
West Michigan
POR-15, original gray. Tough as nails, easy to clean, resistant to most chemicals, used it four years ago and it's worked great.
mitusa
SW Oklahoma
I used polyurethane on mine.....but before I put it on, I made a grid on the tabletop making inch marks and alternating colors of the lines so I could see across the table to the end of the line. Makes it easier to mock things up. I think I used three or four coats.
BellyUpFish
Alabama
A bit off topic, but what vine/ivy is that crawling around your garage?
cheechi
Triad, NC
I use polyurethane also.. lots and lots of it. I have a small benchtop that I put on several coats, after a sand/rub down it looks like laminated store bought benchtop. Every few years I put another few coats on it to make up for the sanding.
My next benchtop will be stained before the poly, when it's finished I'll post up some pics.
Jackfre
N CA
A film finish like Poly will crack when beaten on. The varnish/oil commonly sold as Danish Oil is good because you do protect the wood, but have a surface that is not slick or reflective and is easy to re-do. Depending upon how fancy your bench is a piece of 1/4" tempered hardboard to throw up on it for a particularly nasty job is good to have as well.
gritsngumbo
Monroe, LA
Wow! That's a great idea. I like that a lot and will probably copy you :)
pain
Buckeye, AZ
Your garge looks clean even when it is dirty:lol:
pain
Buckeye, AZ
That is one awesome top. That Rocks:rocker:
CGarage
United States/Switzerland
What should I use on my birch work surface? I want something that is clear that will show off the birch grain but will give protection and that will allow me to wipe off cleaning oils and lubricants, etc...
Thank you!
ItsNemo
Canada
Spar Urethane...a half dozen coats. Mine is holding up incredibly well. I wipe it down with spray nine and everything just comes right off.
ItsNemo
Canada
Yup, that's the same as I used.
Honestly short of mechanical damage (scaping or denting the underlying wood)...it has held up really really well for years. From a fluids perspective, I've had grease, oil, anti seize, thread locker, carpenters glue, engine degreaser, spray nine, wd40, even brake clean...all the usual chemicals you see in a garage on it and it's never even discoloured or flaked or separated or any other damage.
Random pic of it after a few years of use, pretty well as good as the day I coated it:
