What workshop essentials come in a can or bottle?
Jackman
I have the basic stuff, WD40, glue, loctite, cleaners, ect. What else do you guys swear by and can't live without?
TreePointer
PA
Zippo or Ronsonol lighter fluid (naphtha) for removing labels and general stickiness.
GOOP Hand Cleaner for cleaning grease from hands and clothes.
HandyManny
Out West
WD40, RemOil, Hoppes#9, Stabil, Carb Cleaner, Dereasers, Kerosene, 3in1 oil, multi-purpose grease.....
Jim85IROC
Brake cleaner. I can't live without it. I use it to clean almost everything, including my hands. I also keep Kroil and/or Mopar Rust Penetrant very close by at all times.
Americas finest city
X2. Brake cleaner fixes everything. Unless it destroys it. But if it does, you don't want it around anyway.
WG remover
Laquer Thinner
White lithium grease
Guide coat
Etch primer
Weld through primer
Paints and clears
Fillers
Reducers
Simple Green
Mobil1 synthetic grease (red)
PB Blaster
WD-40
Naphtha/White gas/Lighter fluid
Lacquer thinner
Paint thinner
90% ISO Alcohol
Kerosene
Anti Seize
Dielectric grease
TiteBond Wood Glue
RTV - reg and High temp
Contact cement
5 min Epoxy
Super glue
PH + Spa chemical (Electrolysis)
Carb Cleaner
Brake and clutch cleaner
De-Oxit D5
De-Oxit Faderlube
Dry Graphite
Door Ease
Spray lithium grease
Yeah, it's a toxic waste dump...
plinker
Northern Wi
Here's my list, probably forgetting something though.
Loctite sticks (red & blue) maybe some types of liquid too.
hi-temp antisieze (nickle base)
pipe thread compound, good stuff, Permatex or Loctite
Dielectric grease
CRC freeze & release (penatrating oil) works really well
Brake cleaner
Mac's (Napa brand) carb cleaner
CRC electronic contact cleaner
CRC engine store (fogging small engines ete..)
Lubriplate marine & auto guard oil (spray can)
simple green
acetone and or lacquer thinner
Black (500*) RTV
JB weld
super glue
ZRX61
Solar Blight Valley, SoCal
BigAl62
suburbs of Chicago
Duct tape and WD40! If it moves and shouldn't - duct tape, if it doesn't move and should - WD40! Forget about Super Glue, it works on so little it's not worth buying (and it's bond can be broken just by a sharp hit!).
6-Holer
So far it looks like Monte's photo is the only remote reference to Ballistol. Personally, if I ever ran out of the stuff, I wouldn't even bother to turn the lights on until I got some more. I became a fan about 10 years ago, and my enthusiasm for it grows constantly. http://www.ballistol.com/ The only downside might be its odor.....young guys around my shop have told me it smells like really strong "ditch weed", I, of course, wouldn't know. I think one of its best properties is its value as a penetrant. I admit, I've never used the acetone/ATF mix trick, but I'll bet Ballistol can hold its own against it. Try it, you'll like it!
