Plugs every 6' on staggered circuits.
For a one-man hobby shop, what is the purpose of having outlets on staggered circuits?
I suppose this question was for GTFiero.
Until he responds, I can only guess that it's so you'll always have two high amp circuits reasonably available for any project location in your shop? (say for a portable electric heater for you on one circuit, and a heat gun and soldering iron for your project on the other circuit) ...or so it would be easier to use one of these thingies? (the latter was in jest, but then again...?)
Yes, GTFiero mentioned staggered circuits first, and then gtae07 also mentioned it in the post right before mine. I couldn't figure out why one person would be using two high-amp tools at once, but I guess the portable heater makes sense if you don't have sufficient (or any) heat in the garage.
I'm planning a garage build too, and will be doing all of my wiring, that's why I asked.
Which keeps the level of frustration down for me.I treat everything as temporary
I thought about staggered circuits but the wiring seemed like a pain. My renovated carriage house is 23x29. I put each wall on a different breaker. I have a NG heater and welders and lift and compressor have dedicated circuits. I can always use an outlet on a different wall. I have several spaced along each wall. However, my work has not required 2 high amp devices to be plugged in next to each other. If I knew I needed that, I might have done the fancy wiring. Certainly no harm in it.
20190629_072252 by Julian Lopacki, on Flickr
20191013_202003 by Julian Lopacki, on FlickrRun gas line.
8foot doors at a minimum
would make a closed off 3rd bay with 14' celings (for lift) and the rest at 8 feet. Just wasted space dealing with higher ceilings in just a work area.
plan for speaker, tv, projector placement before closing up walls.
I saw some university designs for farm shops a while back and I can tell the guy really never worked in one. Let alone dozens. Had you waking thru tools and all the welding grinding grit every time the building was entered. Forces all the foot traffic in to an isle for not knowing enough to put all the **** along the walls.
Shops are for people, to get around and work on cars and graph paper with a 3 ft ruler don't get it. If it wont break the start is the place to get all you can afford, you can fix other stuff later. Like no substitute for horse power none for square ft and having the building and doors oriented the right way. Often the front is in the back and the back in the front.
I seen a beauty a while back and the couple big regrets they had was didn't get the floor pour for the hoist right and while it was located somewhat fine they didn't account for wet **** and they already needed a steamer and paint bay.
Those are nice but most home brews don't have the space so it all needs to count. A couple minor features could allow for painting without booth that hogged space and not used but on occasion, besides all that **** gets old after a couple years and you want to do other things usually to stuff you really need to do which is maintain cars and living equipment.
Climate and location is a lot. I live in a wet dirty rugged worls and being able to clean, warm and dry is everything. I don't need cad tools, I use a pressure washer and a wire welder and a few hand tools, as few as I can on most days.
As for good ideas, a couple modest island fixed benches with electric on them with shelves under and some overhang to clamp to. Hose reel I can reach for the air and some lights on swinging booms right over the benches. Nite light so I can move without switching up local lights as needed or when I get there. A wash sink in convenient place, a urinal and a potty, a shower not so much. An office in the front, enter the shop, then the office with coffee maker and micro, fridge, desk, book shelf. TV
Get your plans...then add 25%. It always looks bigger on paper [emoji3]
Make it bigger than you think you need. Mine is small at 20x24 (2 car size) and I wish I would have gone no smaller than 24x30.
By the time you get tools and shelves in you'll lose a lot of space.
wider,deeper,higher![]()
If I could do it again? Geez where to start!
Bigger of course.![]()
Build it bigger!
Plug outlets every 6 inches or so apart...., oh and 3-way switches at each door for the lights.
60x80 is roomy. You could subdivide for heat. Heat is like sanctuary, once its inside its safe. In fact could sundivide and sub really. 45 degrees is better than freezing, 50 is bearable and 55 or 60 is workwise but cost goes up. The upside of some heat is simply nothing is as good to keep all your **** in and keep it in service or safe. It don't got to be hot but not good to let paint freeze, dont have to fussy drain some stuff, **** in the car doesn't freeze and cars don't build ice.
I have built in hi pressure washer and cut ice off outside and park in during bitter weather, will take the time to wash, park back in and keep my plow and work truck in. If its bitter out there is a big difference starting out dry, thawed at 50 degrees vs 10. Same parking can be converted to paint. Make a fan could shove in the rear walk door and a curtain for paint.
I built a 40'x50' about 120' feet from the house.
I put in a small bath with toilet and sink. So glad I did and would never be without one.
The ceiling is 12'. In hindsight, I could have done scissor truss and had a higher ceiling. I don't have a motorhome, but when I sell, that might have been a selling point.
I did spend a lot of time and money on a high priced floor epoxy. I love that - so easy to mop up oil or other spills. No hot tire pull ups to date. Very happy and would do it again.
Hope that helps a little.
Spend the money and install foam board under the concrete. If you use two layers, tapping and staggering the joints you won't need a vapor barrier.
I am guessing you will have a 36"-48" footer. After the footer is poured and the forms removed, make sure the inside of that footer gets 2" of foam board also.
If the foam board is out of the budget then you MUST use a vapor barrier.
Plugs every 6' on staggered circuits. Three way switches for lights. Insulated garage doors for work areas. Couple of 220v outlets(compressor and lift). 24' deep apron out front so you can park a truck on it and walk around and unload without gettin off the cement, also great for washing vehicles. Make all man doors 36" wide. Have an out side facet or two, or a no freeze hydrant facet. Vapor barrier under cement prior to the pour. Wire mesh in floor. 6" cement under lift post. Floor drains to outside for vehicle work, or no drain for woodworking. LED area lighting (4000K, easy on the eyes, yet bright). Metal rodent guard at the bottom of your steel exterior if you use steel.
Did them all here on the 30x60', 12'wall, 24x30 shop, 36x30 storage area. Also did 2" foam under shop floor except where lift is and 4' x2" foam board around shop slab exterior.
Pour a pad in front of the large doors when the slab is poured.
Depending on where you live and the climate,, insulate and install the interior sheeting
Wall finish before moving in. For obvious reasons .....
Use jack shaft garage door openers .
No windows, makes it more secure.
Some provision for removable floor tie downs, makes pulling things in easier.
I'd build a big shed BEFORE I got married and had children!
). Kids are older now, so that isn't an issue.Currently have a pole building that's 50'x80' enclosed with a 16' overhang where the access to the second floor will be. I put 5 over head doors along the long wall (north wall) with each bay being pre-determined for what would be inside. Have conduit under the concrete going all over the shed if I need to run anything in the future along with camper dump station inside where we park our unit. Have pex in the floor for in-floor heat so I can hook into that for the winters after I get insulation and natural gas ran to the barn.
Have 60' of pallet racking on the south wall for storage with large windows above that for natural light.
Only things I would change is doing stick built vs pole but thats higher cost along with maybe waiting another year or two to get it up but didn't have that option since the now wife wanted to have the wedding at our property and we didn't have a barn to host it in.
When designing I layed it out so its difficult to see the garage doors from the road and once I get a few more trees up you won't see them at all and had snow removal in mind as well since we get a decent amount here in Michigan. Also have a work station set up under the racking just to the right of the push box for the tractor along with a separate service ran to the shed. Have plumbing installed for bathroom as well right next to the utility room (electrical, boiler, compressor).
Staggered circuits for powering a shop vac and planer at the same time.
Absolutely.
What have others done for an overhead hoist? I have been thinking about adding an overhead beam that would allow me to easily back in a truck or trailer and load/unload very heavy items. The issue is that I am not sure how practical it is to have a beam span the entire garage.
