What would you put on this wall?
MN4x4
Minnesnowta
Between my 'man door' and the overhead door there is a small section of wall that is 29" wide . I originally had my welder there, but I didn't use it often enough to justify walking around it all the time. Now that I am redesigning the shop, I am looking for ideas as to what you would put there?
stonewellmark
Hudson Valley, N.Y.
Spare oxygen and acetylene bottles secured to the wall, or a waste oil drum...with and air and/or electric rell mounted on the wall above. just what I would do.......best of luck.
carpenter383
Maybe an air compressor because it's close to the door for when you need to air a tire up in the driveway.
Fudge
NorCal
Small dorm style beer fridge on a custom steel stand. That way its always right there when you walk in!!!!
Vettman
Ca. Sierras
Wall mounted vacuum. :) Home Depot was blowing these out for $20.00. That's why it's on the 31" wall!
bobadame
A coat rack with a shelf above it for keys, coffee cup, flashlight.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Broom closet. I built on on a short wall and it was surprising what I kept in there. It was 12" deep and 16" wide. I kept the hand broom, push broom, 6' levels, 4' level and other misc. long stuff that you don't know what to do with.
koditten
Midland, Michigan
I have the same thing gioing on in my shop. I mounted my plazma cutter on a shelf that is 6' above the floor and put my floor base drill press below it. IIRC I onlyh had 24" to work with. It works great for me.
Later
Kirk
PaulR
Hadley MA
Garbage barrell and/or small shelf for keys and anything else that needs to be taken out of the garage when I leave.
kbs2244
Make sure you have an outlet there.
Then you can hang an electric leaf blower along side your coat and the fire extinguisher.
When it right there and easy to get at you will be surprised how often you grab it to blow off the floor and get light snow off the driveway or cars left outside.
rickycobra
Utility Shelving: A place for Paperwork, Stereo, Snacks and little thing that aren't tools.
M
MN4x4
Minnesnowta
Mark H:
Great idea - my fire extinguisher is on the OTHER side of the door.
kbs2244:
I *DO* have an outlet there already.
Right now I have a first aid station there, along with a light switch and the GDO control.
I like the idea of a narrow shelf or cabinet and a wall-mounted vacuum. I also like the leaf-blower idea.
Hmmmm - Decision, decisions.....
