What ya call it?
nitroracer20
NY
Lost one to the garage floor abyss.
Whats this thing called, senseis?
  • Like
Reactions: LSU
N
nitroracer20
NY
Sorry for my shortness in the OP.
Thanks - i thought it would be an easy term to search but i struck out!
Any source for SAE slotted round nuts? Didnt see on grainger. Only Metric.
It is indeed a tight clearance fit. A normal socket doesnt have the head room. Before i start slotting / modifying nuts i have on hand id like to put the correct item on.
What an annoying nut to drop!
ok why is the neutral from your source (line side) connecting to the load side of whatever that is?
Norcal
Use a 10-24 nut in it's place perhaps the missing nut will show up in a clean up in the future.
N
nitroracer20
NY
I just ended up using a 10-24 nut with popeye forearm strength on a needlenose. Not trying to make a mountain out of a molehill.
Wire was just pushed over for the photo - Wylie.
Thanks all!!
I Should start a thread, but does anyone have a recommendation for some sort of 30A / 220V rated knife switch? This is a new- old compressor I got. Itemped into my subpanel, but i have to turn it on with the breaker which i dont like.
  • Like
Reactions: LSU
Thanks all!!
ok so is that a pressure switch?
does the compressor not have an auto-off switch?
whats the HP rating on the motor?
N
nitroracer20
NY
Yes a pressure switch.
No auto off switch - motor just stops running when the pressure switch reaches its set pop off pressure ~ 135 psi.
5hp.
Does the compressor have a motor starter?
You will need a 5HP rated disconnect.
Compressor needs to be hardwired unles you use expensive pin and sleeve plugs and receptacles...
N
nitroracer20
NY
Im pretty green, so im not sure if it has a motor starter? I just know basic wiring.
I just know it runs fine now. I really do Appreciate the extra set of eyes.
I have it on 10 gauge wire. Wouldnt a 30amp knife switch (or the 60amp kay recommended) work fine? Compressor is indeed hardwired - temped now though as mentioned - breaker to unit.
Can you post several overall pictures of the compressor?
disconnect needs to be rated for the same or higher HP as the motor. doubt that 30a knife switch is properly rated....
also, what kind of #10 wire did you use? if its NM-b aka Romex, its too small. If instead its THWN in conduit, then its fine.
N
nitroracer20
NY
Motors rated 23.5amps. I did run 10 gauge romex from sub panel to compressor. Its only a 15’ run.
Yes sam im grounded. I think…most days.
Norcal
based on
10 AWG NM cable "Romex®" is not code compliant, it is required to size wire based on 125% of the motor currents listed in NEC art. 430 which is 35A, for a 5 HP 1Ø motor based on the info which was posted by wyliesdiesels which is correct, the OP's wiring is undersized.
N
nitroracer20
NY
You guys are great.
Unfortunately ill size up to be safe. THNN. My electrician buddy is coming in the next few days to help wire up my new garage with surface mount emt. There goes my romex. What say you THNN 6 gauge / 40amp breaker?
You guys are great.
for the compressor circuit? way overkill. use #10 in pipe or #8 NM-b
exranger06
CT
On a 40 breaker?
Yes, you can use up to a 70A breaker using #10 wire if you wanted. I know you're probably raising an eyebrow right now, thinking "how is that safe/up to code? I thought you can only use a 30A breaker with #10." Here's why it's ok:
1. Yes, #10 wire can only safely carry roughly 30A. And your motor only pulls about 23A, according to the nameplate. So the wire can handle this motor no problem.
2. This is a dedicated circuit for this motor only. No other loads will be plugged into this circuit, potentially overloading it and causing more than 30A to go through the wire (unlike a regular receptacle branch circuit, where anyone can plug any combination of devices into receptacles, pulling who knows how much current)
3. If something went wrong with the motor where it's pulling more current than normal (For example, a bearing going bad that makes the motor more difficult to spin), the motor has a built-in thermal overload that will trip before anything bad happens.
4. If something happened to the wiring between the breaker panel and the motor and created a short circuit, even a 70A breaker would trip immediately (a dead short will create several hundred amps of current, much more than 70A).
The whole "#14 wire = 15A breaker, #12 wire = 20A breaker, #10 wire = 30A breaker" thing goes out the window when dealing with hardwired motor circuits. You'll probably want to use at least a 40A breaker to avoid nuisance tripping.
