z28toz06
Haven't posted for a while, but I made this the other day. Wheel dollys are great except when you are not using them. This solved the problem.
what brand are they? Im scared to buy them because everyone says they collapse.
Figured I'd bump this thread and finally contribute to the forum. Here are some things that this forum has inspired me to do around my garage.
Sourced a white board from CL and decided to turn it into the front face of a motorcycle helmet cabinet. Figured if I hung it high enough I'd have room to hang my jackets under it. Worked out pretty well. I decided to keep all my bike oil changing gear (don't worry oils in a plastic pan), car wash supplies, and bike specific tools on the top half of the cabinet.
Had a spare corner in the garage that didn't have much going on in it so I decided to store my cordless drills there. I grabbed a piece of 2X8 and cut out two gun holster holes. I figured if I notched the end I could hang my sawz-all off the end, then I decided to throw a hook on the bottom to hang my circular saw on. Throw in some screws for extension chords, a wal-mart rack for my weedeater, and a small stand for my car battery charger and I'm happy with the outcome.
Here are some better pics of one of the shelves:
<a href="http://s966.photobucket.com/albums/ae141/padstack/?action=view¤t=IMG_0236.jpg" target="_blank"><img src="http://i966.photobucket.com/albums/ae141/padstack/IMG_0236.jpg" border="0" alt="Photobucket"></a>
The shelf is basically a pc of plywood (about 14"x24", I think) on 2 13" shelf brackets. You can just see the angle iron that is screwed to the shelf part that also hooks into the rails to hold it up. Since the bottom of the brackets don't have much to "brace" against, you have to build up something to screw to the bottom of those. on these braces, there was one hole already, but I drilled another one and screwed a second screw in to keep it from twisting. That pc of wood is the same thickness as the rails (3/4" + 1/4"). I have a LOT of weight on there (probably 50 lbs or so) and have no issue at all.
Here are the pics of the high rail with all the brooms, shovels, weed eater, etc hung up:
<a href="http://s966.photobucket.com/albums/ae141/padstack/?action=view¤t=IMG_0235.jpg" target="_blank"><img src="http://i966.photobucket.com/albums/ae141/padstack/IMG_0235.jpg" border="0" alt="Photobucket"></a>
<a href="http://s966.photobucket.com/albums/ae141/padstack/?action=view¤t=IMG_0234.jpg" target="_blank"><img src="http://i966.photobucket.com/albums/ae141/padstack/IMG_0234.jpg" border="0" alt="Photobucket"></a>
I also have one of those weed eaters with all the attachments. TO hang the attachments, I cut some pcs of PVC that had a close inside diameter to the OD of the attachment shaft. Then I drilles a 3/8" hole for the "button" (that you push to detach the attachment) to fit in. Then I drilled a hole all the way through at the top that was offset 90degrees and run a pc of wire through that and make a loop. I then hang that on the hook.
z28toz06, pretty neat! Did you build the drain pan and shelves yourself? Is that made out of wood?
Top side holds spray bottles and shop towels
Bottom has the Funnel holder and drain system for my drain pan.
Ok, I did a search for air tool storage several different ways, but all I came up with was a bunch of cabinets and shelving. I would like to see those trick solutions you came up with. Simple and cheap are always better. Those really troublesome items are great, too.
Here are a few of mine...
I have gotten attached to these rafter hooks. They are about $3 each at most any hardware store.
I use them all over to hang hoses and cords or lumber and framing materials...
But the best use yet has been holding up my air tool hanger...
I had this box of couplers laying around with some reduce bushings, so I grabbed a piece of square tubing and put a hole on the bottom large enough for the stem of the coupler and a hole on the top large enough for the bushing. Now I can plug all my air tools into the hanger with no wory that they may fall and be damaged and the big drawer of my roll cab was freed up for other stuff.
Then there's the angle iron screwdriver rack. I decided to do this after realizing that my screwdrivers were always out anyways, so now I put them back in the rack instead of laying them down on the bench.
I searched all over for reasonably priced socket organizers. There is no such thing and what is out there is not really tailored to my set, so I made my own with a 3/4" slab of particle board and a bunch of spade bits. Total cost: $45 including all the drill bits.
Probably the first thing ever put on my walls was my weed-eater rack. Simple enough...
A commercial piece that I consider mandatory for anything with a long handle, these are the Rubbermaid Pro series....
They can be track mounted, but I just use screw-in drywall anchors...
There's mine, where's yours?
Here's a shot of how I got the lawn spreader, weedwacker, and snow shovels outa the way -
The spreader is seldom used, so I put it up high on a large nail in that dead space. The weedwacker, garden hose, and lawn mower are positioned for easy access. During the winter, the snow blower will sit in place of the lawn mower, so having the shovels handy will be a plus.
Here's a simple battery charger rack I made.
Old Oil and antifreeze jugs work well as storage bins. They don't get all moldy if it's damp in the garage. They are easy to pick up and take with you, More convienant than the boxes that screws and nails come in, and after your oil change, they are free. I have an old card file cabinet that these fit great in. It works well for me anyways.
View media item 5189
Love it!!!Here's a simple battery charger rack I made.
