What's the biggest socket/wrench you used?
drivesitfar
I recently bought an inch ratchet probably just because i liked it because it was a Plvmb, but i have used my 3/4 inch with some sockets up to about 1.5 inch. i might need to use some of my bigger sockets once i start to restore a few big vises and tools, but some of you guys using the 4 inchers are some serious bolt turners.
i was looking into a German made Leinen vise and come across this video with the biggest damn wrench I've ever seen. they are only using a 32 MM socket, but two guys on the wrench and look at that vise hold that piece.
enjoy
msnow
That is awesome, I love big heavy stuff. I am amazed that 1" was able to handle that size nut.
I love making tools, the problem is I sometimes forget what I made them for.
I have up to 3 1/2" sockets and I have used it on the base of a tower. It is 1" drive.
If you ever get a chance take some more pictures of your knaack box set ups. They look similar to mine and I am always looking for organizational ideas.
Probably a 2-1/2" wrench for me on hydro fittings
T
toolaholic
PA
Wow you guys use some big stuff! I keep hoping to use some of my sockets bigger than 1 inch and 25mm. Someday.
Exceller8
Banning, CA
I'm fairly complete up to 2-1/2" and 50mm. With that being said, the largest wrench I've ever used is probably 1-1/4". :lol_hitti
NoahG
Detroit, MI
Biggest I know I've used is 1-1/4". Biggest I use regularly is 15/16". I'm sure I've handled bigger with adjustable wrenches I just don't know the actual sizes.
Sent from my iPhone using Tapatalk - now Free
stephen4785
Benbrook, TX
26" open end wrench, 5 feet long used on very large reciprocating compressor piston rod to cross head lock nut. Lifted by an overhead bridge crane, torque measured by a scale attached to the crane hook.
kB Ariel frame? That's the largest wrench Iv used so far.
Are you a compressor tech?
mopwered
Stafford VA
The biggest socket i have used is 5 1/4 on axles i used to work on garbage trucks so there are a lot of hyd i had doubles of wrenches up to 2 1/2 . I made a wrench for a hammerhead it was 10 inches an made of 3/4 plate
plinker
Northern Wi
Not counting truck axle nut socket's, I use a 3-1/8 all the time for the 2" bolts on truck cranes/loaders.
Mooky
PA
Petrochemical machinery engineer. This was on an old 6 throw Atlas Copco. Very reliable machine unfortunately the plant (hydrogen / ethylene) caught fire and was abandoned. Entire refinery eventually shut down and is now being scrapped.
Hammell
Canada
1 1/2 and 1 5/8 a lot on cutting edges of heavy equipment. 1 7/8 to unbolt a Cat D7 C frame.
ecotec
The biggest that I have ever used was a 32mm on a Nissan hub nut. I have sockets for 34, 35, 36, and 38 that I have not used yet.
burke753
Hobbs, NM
As far as wrenches I use 1 5/8 pretty often. Then the biggest socket I use is a 4 7/8 on axle nuts.
burke753
Hobbs, NM
i was going to say about a 6inch on the rear hubs.
Holy ****. What kind of trucks use axle nuts that big? I had to buy a 4 7/8 socket for the front of a 4x4 International 7300 and I thought that was massive. It's the biggest I've seen anyway.
mtnwalton
I'm retired now but worked for 35+ years in the aluminum industry as Machinist. Lots of custom machining but also a lot of maintenance and rigging. I specialized in rolling mills and changed work rolls and backup rolls. Most of my work was under 2'" but occasionally up to 4" sockets on 1" or 1 1/2" impacts. When we tore out some small mills I kept a few nuts that hold down the mill housing in the shoe tracks. They're about 4" hex nuts. I drilled a 1/2" hole in the face to mount swing arm lamps for home. If i remember tomorrow I'll post a photo.
slip knot
Texas gulf coast
I'm not sure of the size but it was a 4in impact that ran the socket. We were putting a reactor column together in a petrochem plant. @60 ft tall and 25-30ft round. bolted the impact to the center flanges and ran @400 bolts in that bastid. every thing ran off air raise and lower the impact with air. run it til it quit turnin then go to the next. Took about 3 days to get the top and bottom head installed.
mtnwalton
ok here's the photo of one of the nuts i salvaged from a rolling mill. I said I'd post it; just to prove i'm not lazy and i keep my word.
kiatech
Toledo, Ohio
Used some big stuff taking off wheels from heavy equipment, don't even know the size. Just grabbed.a socket that fit. The biggest known size is 36mm
