What's the proper lube?
coburja
For you guys "in the know", I was hoping you could help. What is the proper lube for the front and rear diff and the transfer case for a 1997 GMC 3/4 Ton truck?
bigdav160
Deep in the heart of Texas
Use synthetic gear lube, your trucks side bearings will thank you
Is this a push button transfer case? Does it have an "auto 4x4" position? That transfer case uses a special fluid only available from GM.
Ulrick
Texas
Its regular 80W90 GL5 in the axels, ecxept the 11" Dana takes 75W90 Synthetic.
Transfer case ATF dexron III
acidise
Got a 98 1 ton. Went through the same thing. Use synthetic 75 w 90 in the diffs. atf in the xfer case if it's a floor shift. Auto push button = fancy gm only oil. Same as above. Check owners manual cuz some diffs need "friction modifiers" additive. Usually only if it's a limited slip/ posi trac. Open diffs are plain, synthetic 75 90.
lotsoftools
Inland Empire
It is the option G80 that needs the friction modifier
