What's your shop temp inside and out?
Rc_Guy
Minnesota
-17° outside 40'X48" attached garage is 58°, I keep it about that unless I work out there all day then I'll turn it up.
finn
The UP, God's country
I don’t think a general answer means much because of variables that most people don’t consider.
In NC the freeze depth is probably not over a foot or 16”, so the slab should stay warmer than here, where the frost line is 42-48”.
I generally try to heat the garage to the upper 40s in the afternoon, and the thermal mass of the slab will keep the garage around 32 degrees for the next morning.
However, two things changed this year. First, we’ve had an unusually long and deep cold spell, with sub zero temperatures for several weeks, so the slab is getting colder than normal.
Second, I bought a compact tractor with a snow blower. It probably weighs four or five thousand pounds. When I park it inside, that mass is at, say, -10 degrees, so the slab will cool off much faster than before as the tractor stabilizes at room temperature and the residual snow melts.
PCustoms
VT
Basement shop, 3 of 4 walls below grade. Walkout wall has one framed in (2x4 insulated) door and the other half is an insulated garage door with extra gasket where the door hits the framing.
-13F this morning, shop at 50F. Concrete returns on the front wall (completely above grade) have a nice frost layer. Think I'll stud those out and insulate next summer
930dreamer
Amarillo,TX and Stinnett,TX
7 degrees out at 8am, drove out to the shop and it's 40 degrees inside, the Fisher stove Wil heat things up shortly. Shorts and shop sandals are probably not the proper attire.
ford33
Chicago, IL. USA
Chicago outside air temperature right now is minus 9 with wind chill of -21. I just checked in the garage and air temperature is +30 with no heat running. It is an attached garage and well insulated. I don't plan to work in the garage today.
vertguy
SE WI
-10 outside and I have the heat set at 40 in the garage (mainly to keep the sink from freezing).
Dpmulvan
-11 here 60 in my shop 24 by 28 insulated running a 45 btu propane heater with seperated combustion 2 100lb tanks with auto changeover.
NUTTSGT
Northern Central Ohio
It was 0 when I came home outside and 44 inside after a day and half of not having afire going. Usually it's in the low 50 but this cold snap is cooling things down more than normal.
lakeroadster
Central Colorado
I recorded temperatures.. sun shinning on the barn steel helps.
This thread has inspired me to ask the pro's here for counsel.
Passive Solar In A Steel Sided Barn
firworks
IL
It's -15F out, and my garage is 30F with a heater on. It shares a ceiling and two walls with the rest of my house. My garage door is the original rotted out wooden door though so it's not appreciably better than the door being open. I hope my stuff in cabinets is a little warmer because the whole reason I've got the heater out there is to keep paint and glue from going bad.
Reflex
Outdoor temp this morning = -9 F
Indoor shop temp this morning = 63 F
Shop size = 42 x 56
Ceiling height = 12' at hip 13' 6" center
Type heat = radiant
Odd features = 32' door on west side
Total calculated heat loss = 39,400 BTU/h
Design temp = -10 (75 degree delta)
Heat source = A.O. Smith GDHE-50 Also known as a Vertex 50 (50 gallon, 100,000 BTU/h tank type, 96% efficient).
Gotta love radiant heat
D45
NW INDIANA
Same here in NW IN.......my shop temp dropped to 29
Just have wall insulation and soffits on 1-1/2 sides of the garage, in addition to 6 foot vents
Turned on the 75K heater and in less than an hour the temps were 68 :rocker:
soob
My shop is insulated. I leave the lights on and it stays 25 degrees warmer than the outside.
T5HO = t5 heat output. Man.
Kaizen
New England
-5 in and out today. Not much work being done this winter
T_R
Maine
4 right now and about 50 in the garage I'm running the propane heater. I'm working in there today.
Nights have been about -10 lately and I haven't been running the heat at night. So it drops to about 20 or so inside
I just finished my insulation in the garage now, going to start wiring for my heaters in a bit, they are due to arrive tomorrow. After that I will probably keep it around 40-45 all the time when I am not in there and 50-55 when I am.
driftpin
Seventy-eight degrees F in Coral Gables FL. Spent some time today cutting a table top 3/4" plywood & masonite for a 12" radial arm saw I got off CL.
I also hung a pic of "Jumpin' Jack Flash" that I had in a frame, above the garage OH door. Who doesn't like 1960's Rolling Stones? "Satanic Majesties' Request' and 'Let It Bleed' are two of my favorites.
stingry
Western Nebraska
Western Nebraska. 3* now been mostly single digit and below zero since before Christmas My shop is 3600 sq ft R25 walls and R40+ ceiling plumbed for radiant but not connected. 2” XPS insulation under slab. Currently 35* inside. Slab temp is 35* and just below slab insulation it is 52*. Has never been below freezing in 5 years Happy New Year!!
Thumper68
Duluth MN
After reading the OP I had to go and check, the system logged -22F over night outside and 65F inside.
Ken Greene
Halfmoon NY
-5 outside.... 68 inside 20x22x9 insulated freestanding shop with custom built insulated trifold door. Heated with fijitsu mini split.
Slupie
Bartlett, IL
-3°F for a high today and non insulated, north facing garage was at 28°. My garage has not been much above freezing since this cold snap started.
Dragfluid
Pillager, MN
A little cooler up there, eh? It was only -15 this morning here (Dayton), but -17 the two previous mornings. Have been doing some cabinet painting this weekend, so the inside temp has been kept in the 60's.
THF409
Coatesville Pennsylvania
It’s 10° outside and it’s 65° in here, 26x36 shop insulated and 10 foot ceilings. I’m using a 10,000 watt king electric heater. Southeastern Pennsylvania.
millbilly
Central Illinois
- 14 here in Central Ill Wind chill -35 My shop is 30 x 40 its insulated pretty good. I heat it with a corn stove.......45 is as warm as I could get it today.
PWC Repair
Arkansas
10 outside right now, 36 in the shop. No heat hooked up yet but the little radiant keroseen heater does ok. Will bring it up to about 50 after its on for about 3 hours. 30x48 with 12ft sidewalls and 17 ft peak, open span.
bobbyjean
hudson valley n.y.
2 this morning-yep that's 2 degree's.....the big maxx heater is set for 40...waiting to see how long the lp lasts(100lb) tank...i will say that the garage will stay 15-18 degree's warmer than outdoor temp...at least it did last year ,i used a torpedo heater only while working in there,after 3 days of not using it -temp was 15 above outdoor
i was interested in it to see how the insulation job was working-it's 5/8 rock with r-38 in ceiling.. walls -two courses of 1 inch greenguard foamboard r-10,airsealed everything
bobbyjean
hudson valley n.y.
that's awesome- i was gonna go with ductless unit but i'm cheap and needed heat more than a/c,also had concerns of heating capacity at low end of operating range-i was wrong i see :thumbup:
T
TheEquineFencer
Farmville, NC 27828
12* outside 49 inside the main shop area above 80* in the bathroom and around 70* in the office, I turned a fan on in the office to blow the heat out into the shop....heater refilled a few minutes ago...There's been a spike in wood usage in the past few days...Thank God I have a LOT of wood cut and split. At the present rate I have enough to last 2+ months.
I need to finally install truly automatic controls on the radiant heat now that I have the $$$ to do it. (15 years with a jerry rigged system)
Outlander
Quebec, Canada
-20c (-4f) outside, 55f in the garage currently.
Argh - the "Can-Am Garage" is un-insulated, and heated when I need to with a propane bullet. I did manage to get it up to about -3*C the other day after leaving the heater running for an hour or so. Yesterday, however, I had to change ATV tires (long story) and I ran out of propane (of course). No wind and a few halogen lights turned on meant I was able to do the job and survive to tell about it. "55f in the garage" is but a dream....Mrs Outlander (minister of finance) needs to make provisions in the 2018 budget.
Its official!!! Hell has frozen over here in Northeastern Indiana this morning :evil:
I believe this to be true in other places, all of hell is freezing over not just parts of it :evil:
Worst part about this would be trying to convince the 'no such thing as global warming' conspiracy theorists they are not right. "Colder in Canada than the Antarctic" or "Mars" :scared: does not make for quality garage time in my circumstances!
Santa brought a radiant heater to go above my bench. That should help going forward, but it' to darn cold to install it :spit:
MrSurly
East Texas
Ambient 19F (in Texas) inside the spray-foamed 30/40/14 it’s 47F .
Until the big Maxx gets here, I’m using 1500W cube heaters. I have three to run when I’m in the shop but left only ONE running last night. That foam stuff really works well.
zmotorsports
Northern Utah
My overall shop size is 50'x60'x16', using 2x6 construction. Our overnight temps here in northern Utah lately have been in the low 20's, we had a few days of high teens but for the most part have been hovering around the low 20's overnight and mid to upper 30's daytime highs.
When working in the shop I bump it to around 62 degrees and I turn my T-stat down to 50* when I close up for the day/night. It pretty much stays around that 51-53 degree range all night in the shop side that's heated which measures 40'x50'. The entire building is very well insulated but my RV storage bay side which measures 20'x50' seems to stay around 43-45 degrees.
The heater does a good job of getting up to my occupied setting rather quickly and the heater doesn't seem to run too awfully much once the desired temperature is reached either so I am curious to get my first gas bill here anytime as this is the first winter in the new shop.
b-boy
Buffalo NY
We're hovering at around 6F for the last few days. I keep my garage at around 50F to keep my beer from freezing. :D
