GPAF1002--------21-Midget combo wrench-15 degree offset
GPAQ0501-------24-Flare nut wrench set
GAAD1204-------25-Reversible gear wrenches
AEAT1313-------25-Open ended wratcheting wrench-13mm
AMAA2920------32-8" adjustable wrench
AMAA3830------32-12" adjustable wrench
ANAG1625-------33-1/2" drive torque wrench 50-250ft lb
ANAG1225-------33-38' torqe wrench 40-250 in. lb
GAAQ3704-------36-1/4, 3/8, 1/2 6pt socket rail set
GAAQ3703-------36-1/4, 3/8, 1/2 deep 6pt rail set
GAAQ1312-------37-3/8 12pt rail set
GAAQ1102-------37-1/2 12 pt rail set
GAAQ1313-------38-3/8 12pt deep rail set
GAAR1402-------38-1/4, 3/8, 1/2 star socket rail set
CAEA0812-------39-1/4 to 3/8 adapter
CAEA1208-------39-3/8 to 1/4 adapter
CAEA1216-------39-3/8 to 1/2 adapter
CAEA1612-------39-1/2 to 3/8 adapter
CAQA1255-------39-3/8 ratchet unit
CAQA1660-------39-1/2 ratchet unit
GAAG0804-------41-3/8 star bit socket rail set
GAAG0702-------41-3/8 hex bit socket rail set
CJBT0816---------42-1/4 gearless ratchet
CJBT1220---------42-3/8 gearless ratchet
CJBT1627---------42-1/2 gearless ratchet
CJBG0815---------42-1/4 reversible handle-36 tooth
CJRG1220--------42-3/8 reversible handle-36 tooth
CJBG1627--------42-1/2 reversible handle-36 tooth
CJBM0815--------43-1/4 reverible handle-72 tooth
CJBM1220--------43-3/8 reversible handle-72 tooth
CJBM1627--------43-1/2 reversible handle-72 tooth
CADC1238-------44-3/8 speed brace
CADC1642-------44-1/2 spped brace
CAAH0804-------45-1/4 extension-4 inch
CAAH0809-------45-1/4 extension-9 inch
CAAH1203-------45-3/8 extension-3 inch
CAAH1206-------45-3/8 extension-6 inch
CAAH1209-------45-3/8 extension-9 inch
CAAH1605-------45-1/2 extension-5 inch
CAAH1610-------45-1/2 extension-10 inch
CAAJ1615-------45-1/2 extension-15 inch
CAAJ1624-------45-1/2 extension-24 inch
GCAL9401------55-58 piece pro screwdriver and bit set
GDAD1002-------59-1/2 deep impact set
GDAD1807-------59-1/2 impact set
KAAF1205-------61-3/8 air ratchet
KAAF1605-------61-1/2 air ratchet
KAAA1660-------61-1/2 impact
FTEA0806-------71-reversible ratchet screwdriver
DBAB2206-------75-6in. combination pliers
DFAB2206-------75-6in. long nose pliers
DFAB2208-------75-8in. log nose pliers
DHAA1206-------75-6in slip joint pliers
DHAA1208-------75-8in slip joint pliers
DDAA1210-------75-water pump pliers
DCAB1205-------75-straight external snap ring pliers-5in
DCAB1207-------75-straight external snap ring pliers-7in
DCAD1205-------75-straight internal snap ring pliers-5in
DCAD1207-------75-Straight internal snap ring pliers-7in
DAAR1A07-------78-strait jaw locking pliers-7in
DAAU1A11------78-c clamp locking pliers-standard tip
HAAB1038-------80-dead blow hammer
HAAD1633-------80-claw hammer
JEAB0330-------88-Fork type ball joint separator
JEAC0137-------88-coil spring compressor set
JDAL0133-------88-brake spring pliers
JGAL1801-------88- Caliper wind back tool set
JGAL1601-------89-Auto cup type filter wrench set
JDAK0132-------90-seal puller
JDAN0143------90- valve spring compressor
JJAL0206-------95-2 jaw gear puller-6in
JJAL0306-------95-3 jaw puller-6in
JJAL0312-------95-3 jaw puller-12 in
GAAL0601-------95-ratchet crimping tool
IAAB2508-------96-Measuring tape-28 ft.
JJAF2414-------95-Magnetic tray
JGAT0402-------96-mechanics pry bar set
GAAL0402-------96-Nut splitter set
JGAW0501-------97-5pc screw extractor set
JJAM0144-------97-Telescoping inspection mirror
SAAA3013-------95-hack saw-12in.
JJAG3E63-------95-magnetic pickup tool-telescoping
JJAD1423-------95-magnetic flexible handle
Is that comprehensive enough? I'm a toptul guy, was turned on to them when the less than stellar distributor was located very close to me in Charlotte. I now own over 1K in Toptul tools, and am getting ready to seriously expand. Just purchased some close-out inventory from another distributor that I knew of in the US, so Mike is the ONLY guy I will be dealing with from now on. Anyone that hasn't tried Toptul, don't knock it. I work with Snap-off every single day in class at UTI, and I MUCH prefer my Toptul stuff. In over 3 years of highly abusive use, all I've managed to do is break off a few ratchet selectors from abuse, and break collars off of some of the locking extensions, but I believe they have been redesigned now, so they shouldn't be as troublesome. As far as finish, I'm king of over-exerting my tools. Up until a few months ago, I owned all mirror finish Toptul stuff. I am here to tell you that it hasn't flaked at ALL, still is as shiny as day 1, and has showed no signs of cracking, even after a few of them having a meeting with the impact wrench. Now, judging by the mostly adult age range of this board, I'd think you pessimists could keep your negative opinions to your self, but apparently not. This tread was started in my belief to see what everyone was going to buy, not another import vs. domestic **** list. Do you actually believe that Snap-on makes all those tools? Maybe in the 80's but this is now. Imports can and are better than domestic, need I mention the name Toyota? The import vs. domestic battle has been raging since import cars first came, and it still goes to this day. So it isn't everyone's cup of tea, who cares? Shut up if you don't have something positive to say, and the world will be a much better place. Now, if you aren't posting to say what Toptul tools you wish to buy, I have a novel concept, don't post. /rant.
