jeffmoss26
Justanoldguy, nice collection of license plates! I like your setup too!
No need to be hatin' on the guys who spend time actually cleaning up after each project is done, and take pride in their space, tools and equipment.
Not sure where you are coming from with such another "assumption" ..![]()
took the words right outta my mouth.Nice clamp on drafting light. I've never seen so many hemostats in the same place outside of a hospital or a pot festival...
why do i start to drool everytime jack post's pictures of his shop ?
I'm amazed at how many of you have garage shops that look like your in there every day. With work and 3 boys running us ragged from baseball and soccer every weekend, I just don't have as many hours available. How do you do it? No job? No kids? No wife? What's the deal?
Ya this is normal just clean it enough to put another project down.
[/IMG]
Still working on mine, going to add a few cross braces before painting the frame.
2x2 11 gauge steel tubing, bowling alley top, covered with 1/8" galvanized steel. The bowling alley was stored outside for a few years... so I picked it up fairly cheap, but the weather wasn't kind to it. Found the galvanized steel cheap on craigslist.
Dustin - I love the bench mounted engine stand.I made one of those when I raced off road cars way back in the 70's and they work great. That looks like a pretty good engine you are working on!
Stew
Very nice benches. I like the construction of the welding bench. Gotta get a steel top. I'm welding on plywood now, not good. Do you think a metal overlay on the plywood will work, or would I be better off with a thicker top welding only bench?
My 4 hours of labour and baptism of fire introduction to woodwork.
Just completed the main structure tonight at 8pm GMT
Nice notches. I don't mean to criticize your work but it sounds like your new to working with wood. Once you notch a piece of wood and use that smaller portion as an attachment point you have reduced the load capacity to that smaller dimension. Now the notched portion supports all the weight.
The diagonal brace on the top would have been better used straight across the depth of the workbench. It also looks like it was joined together to make it longer. Not a good deal. The diagonal braces on the ends are a novel idea but probably not necessary since the front legs will provide all the support needed for the front edge of the workbench.
Ever read back over an e-mail and wonder why you wrote it? I don't intend to make this sound evil, just thought you might want to improve the structure while at this step in your build.
The notched items are also supported side on by the double width front. But just screwed into the front crossmember from the side.
I added the cross brace on the ends purely to stabilise it a little more as all the legs are orientated the same way an there was around 3-4mm of lateral movement. I didn't want the worktop to be doing any structural work within the bench itself.
The 2x2 round the base was meant to be 2x4 but I ran out of motivation for cutting by hand.
Just to clarify, all timber lengths were one piece with no joins to make them longer.
It is literally my first time ever building more than flat packed ikea wood. But the money saved has made me a little more interested in woodwork now, not too much though. Lol
Thanks for your feedback, not one bit of it sounded "evil". Just constructive criticism which is rare nowadays without a **** slinging match kicking off.
Spent the weekend at my Father In Law's showing off my skills. Fixed the door to the garage. It worked so well you couldn't open the door any more. To fix the fix I used a ball peen hammer. A couple of wacks did the trick.
Then I assembled a flat packed 6 ft. bookshelf from Target. The bottom section wasn't drilled out for the peg and cam connection. Drilled a hole in the loosely packed particle board. The hole turned out a little larger than needed. Now the only thing holding the sides together is the cardboard back.
I gave up on that pre-packaged ready to assemble ****. Take a couple pictures of an item you'd like, then build one yourself with better materials. It often ends up costing about the same price to do it yourself but you get a far superior finished product. Plus, it gives a good excuse to buy more tools and score a few points with the wife - their response is much better when you start from scratch vs assemble from a boxSpent the weekend at my Father In Law's showing off my skills. Fixed the door to the garage. It worked so well you couldn't open the door any more. To fix the fix I used a ball peen hammer. A couple of wacks did the trick.
looking good ,liking the drawers, hows it coming along?
