Where can I find cheap outlet covers?
bluesman2a
Atlanta, Ga.
OK, so I'm getting to the finishing stages of my project and I'm starting to put things together. I've thrown out the idea of plastic/nylon outlet covers. I want some sort of steel/metal.
I have probably 15-20 outlets, so I need to buy a bunch of these. I'm looking for a cheap 2 gang, duplex/GFI outlet. I found some 2-gang galvanized duplex covers for the OTHER side at home depot ($0.94 each), but they won't work with GFI outlets. I'm not looking to change what I have, but SOMEBODY out there has GOT to make something like this for in a galvanized or cheaper metal plate, essentially I'm looking at $5+ right now for stainless.
Raco makes the cover I need for METAL boxes (i.e. not wall plate like I need) model #915C it looks like this:
Anybody know a brand/type I can find these cheaper?
Aceman
Eastern Oregon
Only metal wallplates I've ever installed were stainless, otherwise we use the P&S nylon unbreakables. Go to a store and ask to flip through their catalog....
bluesman2a
Atlanta, Ga.
use GFI breakers and standard outlets.
I hear you, and that's where I STARTED, BUT have you priced GFI breakers? I've got about 20 ckts that "code" requires GFI on. When last I looked the GFI Square-D breakers I would need were $35 EACH. I know this is somewhat unusual, but in my shop, probably 90% of the outlets are on dedicated lines/breakers.
Charles (in GA)
50 mi south of Atlanta
After having read your post about three times, I'm still not sure what you want.
A) Do you want a stamped steel cover for a 4" metal box, just as you have shown in the post? This covers the outlets and supports them also.
or........
B) Do you want a regular outlet cover plate? This only covers the outlets, doesn't support them, the outlets are screwed to a box.
Charles
Jiffycake
You only need to have a gfci protected receptacle for the first outlet on the circuit, the rest are then protected.
Charles (in GA)
here's why he cannot do that................ edit: (not to say he cannot, but to say that it would not make sense to)
Charles
bluesman2a
Atlanta, Ga.
or........
Charles
That would be B). I'm looking for a REGULAR OUTLET COVER PLATE, configured like the picture. I only used the pic cause it was what I could easily find on the web.
Thanks, I understand that. If you go back and read above, again: every box for most of my shop is a separate ckt. That's separate wire. That's separate breaker. Therefore, based on my current understanding, I either need to have a separate GFI breaker on each or the 1st receptacle in each box has to be gfci.
Fast Orange
Hightstown,N.J.
Go to a real electric supply house and have them pull out a Mulberry Electric Products catalog-here in NJ,they're the major source for metal wallplates.You'll find finishes in S/S,brass,aluminum and both wrinkle and smooth white,ivory and brown.I believe they even have a polished chrome.The configuration you're looking for is a standard for them and should be in stock at the manufacturers warehouse.The website for Mulberry is down right now-but I think only distributors can buy from them directly.If you can't get access to what you need locally,PM me and I'll get a price and shipping cost from my employer to send you what you need-UPS for 20-25 2 gang wallplates shouldn't be too bad from NJ to you.I'll give you contractor's pricing to help offset the shipping.
George
bluesman2a
Atlanta, Ga.
Fast Orange, THANK YOU SIR!!! That's exactly what I was looking for. I'll look around on the web/local and see what I can find. If nothing turns up local I'll give you a shout with paypal or something... 20-25 would be about right for me... Appreciate the info!
bluesman2a
Atlanta, Ga.
Armed with the info Fast Orange provided, I scoured the supply houses locally and online. I had people quoting me in upwards of $9 PER COVER. Happily I found these guys online and they had what I needed to the tune of $1.80 per cover, and were VERY pleasant to deal with on the phone. I should have these in sometime later in the week, I'll follow-up then.
http://www.dale-electric.com/detail.php?itemnumber=97672
rburke65
Canfield, Ohio
swgray! Thanks for the passandseymou web site. I've been looking for 5 and 6 gang white switch plate covers for ever. My house was built by an electrician and I have more 1/pole, 3-way and 4-way switches than normal. Thanks for the info!
bluesman2a
Atlanta, Ga.
Quick follow-up: in addition to having some killer prices, and good phone service, Dale Electric has some GREAT service. I put the order in around 12:30 this afternoon. By early this evening I had an email from UPS with my tracking number and an expected delivery date of Friday!
bluesman2a
Atlanta, Ga.
Plates arrived today, as promised. On time, looks to be a quality product, and the transaction went as expected. Gosh why can't more vendors be like this!?!?!
