Where Can I Get These Electrical Connectors?
Northern_Lights
I’m far from an electrical expert and in need of some help. I’m replacing some connectors and would like to know where I can get these same models.
(1) This 16-14 AWG female spade connector. I found some at my local hardware store, but they didn’t have the small first crimp that crimps the end of the insulated wire to really hold it securely. Any idea on where I can get about 15 of these?
(2) This 16-14 AWG end crimp. I’m not even sure what to call it, it’s not a bullet or a pin connector, but looks like it’s just a crimp to go over the end of the wire to help keep the copper strands crimped together so it can be easily inserted into a screw down type terminal. Again, any idea on where I can get about 15 of these or even what they are?
Thanks for any help.
N
Northern_Lights
Thanks for the replies. I'll check both those pages out. Any idea what the 2nd connector is even called or what type it is?
N
Northern_Lights
I know it's not broken off unless they did that on purpose as part of the OEM factory assembling process. As far as I can tell, it just crimps all the copper stands together so they easily fit into the terminal and can be clamped down with a single screw to make the connection.
wssix99
Chicago, IL
It sure does look like a broken crimp. A crimp for going into a screw block still has a blade coming off of it. If you can show us where it goes, we can be of more help.
Firebrick43
West central Indiana
They should have used a ferrule
Jsf721
LI, NY
that is a basic spade / blade connector Amazon
dave*99
Coastal NJ
Whatever this is, it appears a cut may have been made after the crimp was completed. All wire strands except for two end with the brass.
What does it connect to?
Leaflessshadetree
Don't ask.
Digikey, Mouser, Newark. It may be difficult to find a preinsulated terminal with the strain relief crimp. I'd use heat shrink.
Ferrules aren't hard to find but that one looks like a portion of a terminal.
Sno-Pro
The second is a makeshift wire ferrule. It started life probably as a female terminal, crimped and then snipped off. There’s evidence where the terminal screw was.
cpakalolo
You could also just tin the wires that have a ferrule if the terminal doesn't need the ferrule for size. Ferrules are sometimes used to keep the strands together while it is being handled. They may use anything as a ferrule. The spade connectors are easy to get. If you can only find them with colored insulators; you can just use your wire strippers to carve them off. Buying wire terminations can be pretty expensive, difficult and just plain confusing.
NHtoolguy
Gilford, NH
A type of crimp terminal that also grips the wire insulation is trade-named PIDG (Pre-Insulated Diamond Grip) from AMP (now TE Connectivity). These provide effective strain relief but also require a special controlled-cycle crimping tool with two separate dies. I believe these terminals are typically used in higher-vibration environments.
PIDG terminals are available from multiple industrial sources. Crimpers with dies, while expensive new, can be found on ebay at much lower prices.
Personally, I prefer non-insulated connectors. That way I can can use dual wall heat shrink for better reinforcement.
Segue - I like TE Connectivity because they allow small orders and (last time I ordered) did not charge for shipping !
cannuck
Rural SK
tend to buy from 2 sources: automotive stuff from HD trailer suppliers and AC from an electrical/electronic specialty store. Amazon/online stuff is not worth the crapshoot. Also: buying from commercial sources you can and must be sure to have correct tooling for what you are buying.
PCustoms
VT
Most auto parts stores of hardware stores have these. Why use the internet?
Zim
Because generally the stuff stocked at the hardware stores and auto parts stores is trash meant for bubba who needs to crawl under the back of his clapped out truck and fix the scotch lock and ball of duct tape so he can haul his boat down to the catfish hole this weekend
cannuck
Rural SK
Thanks for playing the game. You've done well.
Zim
Like your bus bars, but where's the ground on black side? Heat shrink makes for nice strain relief but if long term and especially in corrosive environment doesn't seal end of wire conductor from long term damage. I fully understand that is a condition that is probably tolerable in this case.
zimman
Mark Twain National Forest
Haven't installed this panel yet and thinking of some modifications. Ground would go off the black buss to the chassis and battery. Power for the ECM is direct to the battery because that's the way the company wants it. This is Edelbrock and Holly does the same thing to prevent a catastrophic disconnect during a running situation causing the biggest fricking backfire ever seen. LMAO
Zim
4xdog
Santa Fe, NM
I get most of my connectors -- TE Connectivity whenever I can -- from DigiKey. With Mouser or DigiKey be prepared to spend a LOT of time filtering all the nearly-identical options to find exactly what you want
And get a decent crimp tool as well, @Northern_Lights. With the right connector and tool you'll be able to make the conductor+insulation two-part crimps you were looking for.
That is why they make "marine"/"dual wall" heat shrink. The inside melts, independent of of the outside, and makes a seal.
I order directly from TE Connectivity. They accept orders for small quantities. If you say you are from a company, they will even send you some (5-10) samples.
My preference is TE Solistrand Sadly, they do not have spade terminals in that product line.
tyromeo55
There are actually 3 different sizes of spade connectors (NOT wire sizes, physical size of the terminal it self).
1/4" (6.3mm)
3/16" (4.8mm)
1/8" (2.8mm)
1/4" is the most common. Finding the other 2 can be a challenge !
Also, In the battery world (like small SLA alarm and UPS batteries) they will refer to the 1/4" size as an F2 and 3/16" size as an F1
Lorydr
Piqua, oHIo
That would be a ferrule for what you describe.
