Where can I get this valve core remover?
nissan_crawler
Wichita, KS
I'm hoping the expertise here will know who makes this tool. I've seen it, but nobody knew who made it, they all got it second hand, and the name was gone. I've searched and searched and I can't find one like it.
It's a valve core remover that screws onto the valve stem itself, and has a screwdriver that stays in it and you turn the valve core out with that. It has holes on the part that screws onto the valve stem for the air to bleed off. The valve core can't come out of the tool and go flying this way, which is nice with 200+ p.s.i. aircraft tires.
It looks like just the round part of this tool:
Plus, one of these through the center of it:
Any ideas:confused::wtf:
cambell
I own one of those, but now that I think about it I havent seen it in years. I believe it was k-d I think I picked it up in aids auto in the mid 90's not positive though. I'm gonna go try to find it.
I just reread your post and thats not what I have. I have whats in the first picture.
jimmycrackcorn
Brooklyn, NY
You rule! Thank you.:bowdown: It's fancier and more expensive, but it's a good start. I haven't even seen anything online before that.
No prob, I should thank you i found a niffty tire gauge when i went to search for it. I could use one of these in the car, it get annoying switching back forth with a gauge and the tire inflator
N
nissan_crawler
Wichita, KS
Oh, yeah I have that one, you missed half the post. Thanks for the help though.:lol_hitti This is an oddball tool. I might end up being cheap and making one.
boiler7904
NW IN
I got a Milton 506 or at least I think that's the model number, inflator / gauge similar to that for Christmas. Used it Sunday to check and fill all the tires (including spares) on the Escape and Colorado. So much easier when you're not constantly switching back and forth between two tools.
boiler7904
NW IN
Will
Snap On GA143A
or
Matco T104A
work?
Both are less than $4.
N
nissan_crawler
Wichita, KS
Will
Snap On GA143A
or
Matco T104A
work?
No, I have those, they don't work, not well anyway.
Um Nissan are you looking for a valve core tool that you can change cores with without letting the air out ? I have one I use on HVAC systems to change out leaking valve cores ? if so I can get you a make and model number.
Rick
Just the opposite, I'm looking for one that holds the core and still lets the air out.
ImportTuner
Charles (in GA)
50 mi south of Atlanta
krisma
this an aviation specific tool adapted to other applications as you can see by the many other ideas that people have posted. this tool can typically stand up to 3500 psi of pressure. it's a safe-cor tool p/n 968rb and they run $30-$40 from my local snap-on truck
972500
north canton, ohio
go to matco's website, i think the part number is VT45 or somthhing along those lines. i would look it up quick but i have to get to class sorry
