Where do I find a shallow wall cabinet?
Ruger_556
I want a shallow wall cabinet (6" maybe?) like this. It's going to go on the end of my tool box for storing paint, cleaners, filter wrenches etc... Where can I buy such a thing? Everything I've found is way to deep at around 12"
NUTTSGT
Northern Central Ohio
Somebody posted a rather large cabinet a while back. Basically it was a man door hung on a 2x4 frame mounted on the wall. I believe the OP (where ever it was used it for spray paint and similar items.
Retrosmith
Texas
Trailer door cabinet?
http://www.pitpal.com/cabinets/deluxe-trailer-door-cabinet/wall-organizer/
Thumper68
Duluth MN
If you can't build one yourself try a sheet metal shop, they make up stuff like this every day.
jgschroeder99
NW Ohio
Well, since the cabinet in your picture is probably a NEMA 3R or 4 electrical enclosure, you could go with the same thing. Cabinets that shallow are easy to find if you go with an electrical enclosure. You get the side benefits of a door gasket, secure latch, and relatively heavy gauge steel. You might get sticker shock, though. Might be able to find a used one on CL, but it will probably have conduit entries cut in it.
http://www.newark.com/hoffman-enclosures/c-sd24166/enclosure-wall-mount-steel-gray/dp/06B6717
