Which air sander?
equalme
Just picked up a 60 gallon Puma 3hp that outputs 12cfm @ 90psi. Looking for a good palm sander for automotive finishing. I had a Griot's garage electric DA sander and I hated using the thing due to the size and weight...I need to be able to use it one-handed.
I've been looking into the Dynabrade 3/16" orbital sanders but am overwhelmed by the vast amount of models they have. Are there any other recommended brands that I should be looking at? Specific models?
Btw I rarely do filler work but I have a electric ridgid orbital sander for that purpose.
Thanks!
Zeke
Just be mindful of the required CFM. Hutchins is a high quality unit and they have at least one below 10 CFM @ 90 lbs. One handed too.
MODEL 4560 SERIES RANDOM ORBITAL
Bill Bowman
Metro Chicago
Dynabrade is light years ahead of Hutchins in quality, IMHO. You may only be able to use either on a limited amount of time, due to CFM and compressor capacity. Bill
Davefr
OR
I have a Sioux and it's bulletproof. However pneumatic DA's are huge consumers of CFM AND at high duty cycles.
I usually opt for electric. (less noise, less power and usually more conveniant)
qwik
savannah ga
I own a Hutchins and 2 Dynabrades, the hutch is overkill for most. The DB's are light and a great universal sander. If you're only buying 1 the 3/16 (fairly aggressive) is probably the best fit.
