Which breaker panel is most common?
micromind
Fernley, Nevada, about 30 miles east of Reno.
If I was buying a panelboard for my shop would lean towards a SQ D NQOB, accepts plug in and bolt on breakers, Cutler-Hammer had their PB panelboard that did the same, but it went away with the Westinghouse acquisition.
Same here, if it's up to me, it'll be Square D but it's NQ these days. Same panel, different name.
BreeStephany
Oregon
If I was buying a panelboard for my shop would lean towards a SQ D NQOB, accepts plug in and bolt on breakers.
It's been well over a decade since I used Square D (employer & engineers loved Eaton's price point), completely forgot about the NQOB panelboards!
It's nice to now work for a company now that is transitioning to solely using Square D!
SouthernIllinois
Translation: Panel boards are always better. Those are the big commercial panels, 20" wide, 6" deep, and height dependent on what the guts are. They come in pieces, separate tub, bus bar assembly, dead front, cover, and whatever else is needed and get put together on site. Of course, there's always a downside and in this case, they are expensive. The last time I did anything that I used a panelboard was in 2018, so pre Covid. I bought a SQD 200 amp main breaker 40 space single phase board with I think 10 QOB120, two QOB230, and QOB240 and two QOB250 breakers and it was about $1000.00. I can't speak for all contractors, but I can't even call up the supply house and get an immediate contractor price. The salesman takes the info and submits it to SQD for pricing. Anyone can go in off the street and buy one, but it's going to be an arm and a leg, or two. If I ever get around to building my big shop it will probably have a panelboard, but in all honesty, a load center is more than sufficient. But a panelboard looks way better...
Thanks....I can speak Navy and Submarines but not electrician...lol
alfredeneuman
Fullerton, CA
Murray was purchased by Siemens.
Siemens breakers are identical to Murray internally and externally except for the markings.
Even both Siemens and Murray breakers are type "MP"
reader2580
Minneapolis, MN
Yep. Siemens discontinued Murray a few years ago, and issued guidance that Siemens breakers will work in Murray load centers while still maintaining UL listing.
Stick-man
Mid-South Tennessee
I know NOTHING about wiring and my electrician gave me a shopping list of everything I would need for my pole barn.
One of those items was a 200 amp, 40 hole breaker panel.
The only one Menards had was a an Eaton - pictured below.
What is the issue with it?
I haven't opened it yet and I can always return it IF there is a valid reason.
Any input would be welcome - like I said, I don't know much about wiring or the associated components.
I just installed this same panel in my shop. I get my inspection on Monday, and as long as I get a pass, the power company will hopefully hang wire to my pole and drop into my outdoor service box. I hope there is not an issue with this panel.
mike93lx
Richmond, VA
It won't pose an issue for inspection
