Strouty
Just trying to be honest!
That is more of an opinion or rumor. Unless you have first hand experience than take a back seat.
KC, the first post says $50.
I am going to flat out say that you must not know how to use a cable come along or any type of cable winch. The only time that they are hurt by abrasion is if the cable is going side to side over something sharp for a long time. We run all cable come alongs and have very few issues that were not caused by user error. I run winches with thousands of feet of cable and that cable will cut through steel when it is moving and it does not damage the wire rope. The biggest cause of damage it when people do not put the cable away under at least minimum tension (as you noted the lug alls do have a spring loaded guard that helps), then they just use it under full load the next time and the cable crushes itself. I agree that chain is the most robust, but not the only option, besides try dragging a 15 foot long chain hoist around all day and see how productive you are.
KC I was talking about winches running over steel, as far as come alongs running the cable over a sharp edge is user error AFAIAC.
I was never suggesting suing a cheap Chinese one, I know that the lug all is one of the best, but also out of the OP's budget. The Tuf Tug is a decent choice, especially over the HF ****.
If you have a come along that when uncoiled tends to ball up like that, the cable should be replaced because it was damaged. I have been building towers with wire rope come alongs and wire rope winches for 25 years and we pull tensions of 8000 plus without issues, you just can't get the chain units to fit where a wire rope unit will fit. As I stated before, I have only seen one fail in all that time and it was due to a repair that failed. I personally own nine 3/4 ton (used for antennas and light towers), nine 2 ton, and nine 3 ton cable come alongs. They vary in age from 5 years to 30 years old. I also have three 4 ton tirfor (griphoists) that are close to ten years old. How many come alongs do you own and maintain?
I am with the experts here and used a quite a variety and own several, in the end the OP has hit it on the head. These are very good with a little care, they last a long time.The 2-ton unit at Tractor Supply is intriguing and gets my vote thus far due to its price point and being made in the USA. I'm not a Harbor Freight fan for a few different reasons but I digress. Will have to get to Tractor supply in the next few days
Yes, as I talk about the 2T in the post above, its the way I basically ruined them, at the time 15$ but going up the next size basically solved the problem.Another reason I like cable is the ability to pull around corners or odd angles. Have I ruined cables doing this, yes but it was worth it to get the task done.
KC thanks for the link to the chain hoists, those are definitely nice looking ones.
I am not trying to win an argument, I am trying to educate people about a particular tool so take it as you will.
Wire rope does not hold a memory to the drum that it is own, wire rope just holds a memory based on the way it is made. The diameter of the wire rope is basically what would determine the size of the coil that it wants to be in. When you end up with a birds nest of tight coils, it is because you were not pulling directly onto the come along or winch drum. Usually the cable rides across the guide on the come along or the body of the come along, sometimes it can actually be an obstruction. Think of making a ribbon for a present by taking the straight material and running it over the edge of the scissors, it wants to curl. That is why I say when a cable does that, it is damaged and should be replaced. If you have an obstruction in the way that the cable will be riding across, you need to either re-rig it or put a sheave of some type in there to deflect it.
Now keep in mind that a sheave can also damage wire rope. The rule of thumb is that the sheave diameter should be as close to 18 times the diameter of the wire rope, you can get away with less, especially when you are not transitioning 180 degrees. So a 5/16" cable would need a 5 1/2" diameter sheave to work at maximum force. When a manufacturer designs the come alongs they design it to work within the specs of the cable, drum diameter, and sheave diameter (if two part), in this respect the diameters can be smaller because they are designed to handle that particular load range. A good come along will have a handle that bends when you try and go beyond 125% of the rated capacity.
When you see a winch on the front of an off road vehicle and they have the cable coming out and going almost 90 degrees to one side, they are damaging the wire or synthetic rope too. People think that adding a roller fairlead or a hawse makes it OK, but they are damaging the cable. Both wire rope, synthetic rope, and regular ropes have to meet a minimum diameter bend radius, when you put the tension to any cable that is tighter than that rating, it will essentially overload one side of the wire or synthetic rope strands. That is how you end up with a birds nest coil of cable. The synthetic rope does not show this, but it can be damaged this way as well. I am sure Bushmech can relate and confirm.
Now when you talked about the wire I use to hold up towers, (EHS Guy Strand or Bridge Strand) that is similar to wire rope in that it wants to coil based on the way it is manufactured not based on the reel it is stored on. When you have a new reel and need to get at the wire rope, you have to take great care getting that end undone, they usually put several industrial staples around it in various locations. We try and get a rope on the cable before removing too many staples, sometimes it has to be a person holding the end. When that last staple comes off, the cable wants to whip around the reel and try and break your nose. The bigger cables tend to have less energy because of the two lays they have (one goes the opposite direction of the other). You still need to be careful because they can and will try and get away from you.
I hope this sheds some light on things.
