Bennylava
Hi all. I am having the usual difficulty with getting a water hose to detach from the spigot. Just the standard stuff on the outside of any house. The part you tighten down (name?) on the hose, has apparently corroded to the spigot. It looks to me like the part on the hose, is made of some kind of aluminum. I should've known better to leave that thing on there, this seems to happen every time.
But with a struggle, I've always been able to get them loose. Not this time. This time it's like I'm going to rip the spigot off the house if I keep it up. There's no concrete around the spigot, just a hole, which is something else that I'm unclear on how to fix. It's just sticking out of a hole in the brick. I sprayed some PB Blaster on there, cause it's all I've got here on hand at the house. Must've ran out of WD-40 at some point.
I was hoping someone else here had one stuck on and knows how to deal with this problem. From now on I think I'll be using the plastic ones.
