If you want a corded model, the absolute best one you can buy is an older model Milwaukee. They are pretty indestructible and replacement parts are still made. Husqvarna is another good one, but I've heard that's also recently been discontinued, but should be enough out there to find. 316e I BELIVE is the model. The only real weak point on that saw is the chain lock lever. It's all plastic, and with repeated use it will eventually crack or break. The makita model is built like a tank. It's the model Home Depot uses as rentals. The ONLY bad thing about it is they have an overload sensor inside that trips any time you try to push the saw hard. It's overly sensitive imo, but it's a very well made saw. I have all of these at work, and the Milwaukee is the first I reach for.
If you want a good cordless, the dewalt 40v is suppose to be better than the new 60v flexvolt from what I've seen online. The 40v is regarded as more of a contractor grade, and more powerful, but honestly I'm sure the 60 would do ok. If going cordless, consider the entire platform you can get along with the platform you choose. People have good things to say about the Ryobi also, but my gut tells me the dewalt 40v is much better..
The key to ANY saw is a sharp chain. Learn how to keep it sharp and your experience with the saw will always be a lot better. A file is good for maintenance, but honestly that HF chainsaw blade sharpener has done dozens of chains for me and brought it back to like new..
A cheap gas model, any really - echo, craftsman, shouldn't be overlooked if you have something demanding, but the corded models have come a long way esp the models I mentioned.
For pictures sake, this is the Milwaukee - kinda dirty looking, but still the best I've ever used.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=302313392427
Just to put things into prospective, all the corded models I use are for cutting telephone poles.. way above the needs most homeowners would ever need. ive also had a cheap Remington limb and trim last about a year or two kicking the hell out of it at work. If you just need something for basic stuff, not everyday use, probably any of the homeowner grade models will be fine. Come to think of it, I've had a corded homelite that was very good too.. just decide what you wanna spend, and read reviews. With half a brain any of them will last a long time for general use. You don't NEED to spend a ton of money. The cheaper corded models will also be a lot lighter. The pro models are made with everyday use in mind. They are nice to have, but not necessary.
I wouldn't be above looking at the homelite or worx models.. sounds like they may be more inline with the needs.
