I probably know the answer already, but the only thing I ever see around me on CL is ShopSmith multi function machines. Are they worth any time or money for metal working or is it mainly for wood and simple hobby stuff?
Did you see the South Bend movies that are out there?THAT IS A GREAT LINK!!!! THANKS!!!!![]()
There real old, look like something that would have been shown in my high school shop class in 69, and they were old then.
I will try to find the link, I think I need to download them again.
These are good too.
http://metalworking.com/tutorials/ARMY-TC-9-524/9-524-index.html
Grinding Your Own Lathe Tools
http://www.sherline.com/grinding.htm
I can't find the videos right now, If I come across them I'll post them.
Yeah, if it's the "Shop Smith" I am thinking of, the only "Shop Smiths" I ever saw were for wood only.
>Forget the China **** and look for well maintained old U.S. or European tools.
A good idea but not very practical in Texas. You got lucky. I looked for a while before I popped for the HF unit. Nothing around here but worn out oil filed junk, usually huge. Or well used equipment that needed rebuilding for the price of new. I can hold under .005 on my cheapie, which is plenty for me. The mill is pretty tight and holds well for what I paid. I did not hold high expectations, so that helps. I'd trade for a Bridgeport, sure. I had a line on a 13x40 Logan but the guy would not turn loose of it. Everything else that has come up in the last 3 years is huge or trash. I'm just not that lucky - yet!
Here is my little 15x30 LeBlond Regal Servo shift. Its a fairly modern machine; full inch/metric, 1800 rpm spindle, 2.250 spindle bore. It has a L1 spindle taper and I have a 3 jaw, 4 jaw, drive plate, and the shown 5C collet closer. Needs a readout or at least a travel dial, I get spoiled from work!
Picked up this Clausing 12x36 off Ebay a couple weeks ago, in the process of cleaning it up to replace the Atlas listed earlier in this thread.
Nice looking lathe, now get that chuck key the hell out of the chuck! haha
Just a little SB 10L (Heavy Ten). Just some routine maintenance of the compound.
Just finished restoring a 1961 Logan Model 1955 11x24" lathe. Before and after photos shown. It's about 95% done in the photo. Just needs the gearbox chart plate and VFD installed.
My personal lathe is a Harbor Freight 8x12 (actually 8x14) which I got new in 2006 and have been very happy with. No pic of that one.
Yes, and still is.Beautiful restoration.
Was that a school metal shop lathe?
Nice! Mine is slightly older. Did you wire it to a VFD?
Nelson
How do you like your heavy 10? Where is the saddle?
I F-ed up big time last week by not buying that exact same lathe in grey on the spot for a grand including the rotary phase converter. Ill get the next one though.
Been using my little SEIG lathe a lot in the last few weeks. I just want a bigger lathe that has QUICK CHANGE GEARS and a taper attachment!
Chris
Nice to see I was not the only one who cringed.
That's the same lathe I run in the Toolroom. I find the LeBlond lathe to be a great lathe for the size. I don't know how many times ours has been moved around, but it is excellent as far as accuracy.
Just a little FYI for anyond purchasing a lathe and if you would happen to run across a Hardinge Speed Lathe, or Hardinge Toolroom Lathe, you need to check the Compound for wear. Tubalcain discusses the Hardinge Speed Lathe here towards the end of the video http://www.youtube.com/watch?feature=endscreen&NR=1&v=nYni5QP0qyw It is the short lathe with no tailstock.
What happens is that there is no way to lube the compound on them, and over a period of time, the compound will wear. Once it does, when taking a face cut, you can feel the compound jump slightly. Another way to check is to back the compound all of the way out, then wiggle it with your hand to see if it is loose. If it is, 9 times out of 10, you cannot adjust the gib to tighten it up. Normally with the speed lathe, most of your work is done in an area of just a couple of inches, average. If you tighten the gib to take up the slop, if you are out of the certain couple of inches, the gib will tighten up to where it is very hard to turn.
The Hardinge Speed Lathe is very precise. And if the compound is sloppy from wear it kind of renders the lathe useless. To have the compound sent in to Hardinge for a rebuild cost big money. For a new compound...$10,000. For Hardinge to rebuild the existing compound $5000. And I didn't add an extra zero either. I've had to send ours out twice to have it rebuilt over the years. It seems like a ridiculous price for no more than what the compound is, but it is one of the main features that make the lathe. Without it you're pretty well screwed and they know it.
The compound is shown here. This type of compound does not have power feed or power crossfeed. So if you would happen to run across one for sale, make sure you check it out by running the compound out to it's limit.
I have a lot of "extra" tooling, need to be careful I know about saying I have extra tooling on garage journal!
I am a novice lathe person, have used it a lot, but never had the shop I have now. now that I am organizing and using the equipment more I relized I have collected too many parts.
does everyone usually sell the extras? or trade them for what they need? as I am doing inventory I noticed I have 4-6 4 jaw chucks, 2-3 3 jaw chucks 2 milling attachments...... you get the idea. I dont have a taper attachment, and a few other things. so is it better to try to find a machinest and trade? or sell these and buy what I need??
I seam to have this very hard time selling or releasing tools!
most of these are for southbend lathe I believe.
link http://www.garagejournal.com/forum/album.php?albumid=1674
I kick myself in the A$$ for not getting a hold of him when it 1st showed up on cl
