HanShotFirst
12 points are good on 1/2” drives for when you need a breaker bar. Sometimes you just can’t get in there with a 6 point, and a 12 point gives you more options.
I don't think I ever saw a 6 point socket for sale in Europe in my 12 years over here.
I use impacts for mostly everything and they're all 6 point. I have a large sockets set i bought when i first started out however and they're all chrome 12 point, i'll use them if i need to get a fit on a fastener in a tight space. I've never rounded a bolt with either type of sockets, all the bolts i've rounded have been on lines when using the open end of a spanner.
[/QUOTE]I don't think I ever saw a 6 point socket for sale in Europe in my 12 years over here. I'm sure the European companies do make them but they certainly aren't readily available or carried in stores. Of course you don't see many cars older then 5-10 years old driving around so maybe rusted bolts aren't as big an issue. I've had BMWs since 1999, several were over 15 years old, and seemed much less rusted then my Chevy's and Fords when I lived in the rust belt back home.
Why stop with 12 pts? I rarely use SAE sizes. The myriad cars I wrench on now are all metric.
When i updated my tools recently I only bought the range of metric sizes. I'm not getting rid of my 12 pt sockets & wrenches -or- my SAE tools but i did note in my sample size (of 35 years) that i rarely used them.
There are definite exceptions, I had to BUY a 30mm 12pt impact to remove an axle nut for a VW wheel hub but that is what the nut was 12 pt.
God, I hate SAE.
Who likes fractions? Metrics is so much more intuitive. "Hey, grab me that 30mm!" as opposed to "Hey, grab me that 8/64!!!!" lol.
God, I hate SAE.
Evidently a lot of people love SAE (or English) sizing. Otherwise we would have changed. (Abandoning American exceptionalism??) We would be so much better off if we were dealing with miles vs. Kilometers, or lbs. vs Kilograms. It has crept into use for containers like 2 Liter bottles of soda.
But doing a bunch home improvements it is ALL English. You get 4x8 sheet materials and frame with 2x4 (which are not 2x4 anyway). Makes you wonder what they sell up in Canada?
I'm just going to leave this here for anyone that thinks 12 points grip as well as 6 point on 6 point bolts.
Rounding or stripping is all about material displacement. When the nut or bolt starts to round off, where does the displaced metal go?How the fit looks on the pic is deceiving, it looks like the fastener fits into the 6 point opening almost perfectly but of course this isnt the case. When the spanner is turned the vast majority of the load is still applied just back from the corner of the fastener, shown below;
A good 12 point socket or spanner with a modern profile will also apply the majority of force onto these flats, commonly called flank drive or OGV;
Obviously this is from Facom but every other make will be similar, if the bolt starts to round then more material would need to be moved out of the way for the fastener to turn freely inside a 6 point socket than a 12, but its not much more and the bolt would have to be very soft or badly corroded to let that much of it deform.
A lot if it has to do with bolt hardness. Old equipment companies like International Harvester made there own bolts that were harder than today's fasteners. You can use a 12 point socket to take off most bolts on a 40 year old tractor but you need a 6 point to take off fasteners on a 5 year old car without rounding them
I've dealt with both metric and Imperial in the Army, and as a Civil Engineer in both Europe and the US. I have to admit the metric system makes more sense but my American stubbornness still prefers imperial (English). I'm fine with meters, adapted to the temp in Celsius, but still feel that motors should be measured in good ole Cubic Inches, especially V8s. I still convert gas from liters to gallons and Euros to dollars so I have some measure of what I am paying, and convert gas mileage from liters/100km to mpg. I still have my Chevy so I get to use my SAE tools occasionally although it is a frustrating mix of metric and SAE. Often on the same part.
Hello guys old post but unfortunately missed the real inside knowledge, the only reason 12pt sockets became so popular and companies are pushing it on us is the fact that they do not brake, these sockets are immortal what they do is round up your nuts so its your problem to deal with! No warranty replacements no bad reviews no problems for them, it's even good for business cause once you rounded enough nutsyou are gonna come back to the store and buy another 6pt set! It's a perfect little con. ;-)
Or a Quincy 325 air compressor
There are certain brands of sockets (and wrenches) in 12pt that are more reputable for this alleged trait than others.
Maybe we should start polling these people rounding off bolts to find out the details.![]()
Some bolts have 12 point heads. Like on ford drive shafts.
Trouble is you need both these days, Harley for example has a mixture of both fastners in both SAE and MM on each bike, the bastards!
