...yup. It'll drive one nuts trying to figure out what's foreign, what's domestic, etc...
For a vehicle's final point of assembly, the first digit of the VIN correlates to:
1- USA
2- Canada
3- Mexico
5- USA
K- Korea
J- Japan
I forget what Europe's designation is... 4 perhaps? And I've encountered the H designation a few times as well - Hungary?
The number 4 is also USA. Six is Australia. W is Germany. H is not used as a first character anywhere in the world.
A link that explains EVERYTHING about 17-digit VINs:
http://www.angelfire.com/ca/TORONTO/VIN/WMI.html#ccode
# Position one represents the nation of origin, or the final point of assembly. Cars made in the U.S. start with 1, 4 and 5. Canada is 2, Mexico is 3, Japan is J, and Germany is W.
# Position two tells you about the manufacturer. For example, A is for Audi, B is for BMW, L is for Lincoln and N is for Nissan.
# Position three tells you about the make.
# Positions four through eight tell you about the car, such as the series, body type, restraint system, and engine code.
# Position nine is the check digit, a number from 0-9 or the letter X. Law enforcement officials can detect if you've tampered with the VIN by this character.
# The 10th digit gives you the vehicle's model year. The letters from B-X correspond to the model years starting with 1981, with Y bringing up the rear with model year 2000. There are no letters I, O or Q. Here's a list of the model years: B=81, C=82, D=83, E=84, F=85, G=86, H=87, J=88, K=89, L=90, M=91, N=92, P=93, R=94, S=95, T=96, V=97, W=98, X=99, Y=00. Beginning in model year 2001 the manufacturer's made it a little easier and made the VIN's 10th digit mirror the model year as follows: 1=2001, 2=2002, 3=2003, and so on through model year 2009. So if you are not sure about a vehicle's model year always double check the 10th digit of the vehicle's VIN.
# The letter or number in the 11th position indicates where the vehicle was assembled. For instance, 9 identifies that it was made in Detroit, Mich.
# The last 6 digits are the production sequence numbers.
