Why can't I buy a...
383 240z
Findley Twp. Allegheny Co.
Looking for a cover for a GFCI in stamped steel for a 2x4 handy box. I can find them in nylon/plastic, wood, and decorator covers. However I want plain stamped steel, that will match the switches, non GFCI outlets and such.
Do they exist? Or should I not have a GFCI in that size box? It's a single GFCI on a 20amp breaker fed with 12/2. Nothing else on that circuit.
Norcal
The first mistake is using a handy box in the first place, with a bulky device like a GFCI receptacle it's like trying to stuff 10 pounds of **** in a 5 pound bag, 4 sq box with the appropriate raised cover works better.
gregtwojeeps
Ky
Assuming you want surface mount and instead of using the small handy box... would these work for you ?
MushCreek
Upstate South Carolina
I've noticed that our local big box stores don't carry them in plain stamped galvanized to match surface-mounted boxes. I know, cuz I looked, and even asked.
383 240z
I found one that's close on Amazon, asked in both the orange and blue big box stores. Going to check Yesco (local electrical supply) next time I'm over that way.
I don't think I overstuffed the box, the hot and neutral land on the GFCI, a pig from the box, one from the outlet, wirenutted to the ground coming in.
Yes this is surface mounted, it's in our barn. That's why I don't like the nylon ones in there. They don't look right in there. Everything else is galvanized steel.
Looks like I'm swapping the boxes out for some 4x4's if I can't find them
kaymccampbell
Upstate New York
You could take a galvanized switch plate and customize it for the decora hole. I have a whole bunch of handmade plates because I can't find the plate I want with the hole I want. It takes maybe 20 minutes to hack the custom hole and you're done. Cheaper than wasting my time hunting through every usless big box on the planet.
