Why does everyone stop the coating inside the door???
SteveL
St. Louis, MO
Curious why every picture that I've seen has the coating stopping short of the driveway inside the door. Why? I have had Benjamin Moore Epoxy down for almost 10 years and it goes all the way outside to the driveway. No yellowing or fading what so ever. Am I missing something or are all of the products talked about here of a quality that will yellow or fade over time? Maybe I should just redo with what I have if that is the case.
Or is it a matter of asstetics? I personaly think it looks weird having just a small strip of uncoated concrete floor showing.:headshake
mike944
Vernon, CT
i ran my epoxy under the door, right out to the lip of the concrete. I do have some slight yellowing after a year and a half, but not too bad.
(Armorseal 1000HS)
boiler7904
NW IN
I stopped at the lip in the concrete which happens to be about 3" inside the face of the door. That seemed like a better idea that trying to mask a [straight] line directly under the door when I did the floor.
Yellowing of the top coat was also a concern.
JohnZ
Washington, Michigan
I had mine done seven years ago out to the driveway joint, so about 10" or so of the epoxy coating is outside the door seal; has stood up very well physically, but UV has lightened it quite a bit compared to the floor inside the door - it gets full sun until about 1:00 PM.
S
SteveL
St. Louis, MO
I guess it depends on the type of product used. The Benjamin Moore product that I put dow about 10 years ago is rated for outdoor use as well as indoor so I would assume that it is more resistent to UV fading. I have had very little color change in mine over 10 years. I think I've decided to use it again to recoat my existing floor and the new addition. I can have it custom mixed for color and they offer a clear to cover the colored chips that I'm getting. Thanks for the feedback.
Baer
SE Pa
Ran mine out to the end and will (hopefully!) pave up to it soon.
