Blacknwhitepit
I am getting a bit frustrated now. I have a 33 Gal Craftsman compressor. It is rated for 15 amps. Now I originally had in on a 15 Amp service outlet. It would get to about 90 psi then trip the breaker.
I installed a dedicated 20 amp line (I used the correct wire as well) on a 20 amp circuit breaker with an outlet rated for 20 amps.
Here is the kicker now. It charges air up until it automatically shuts off (125 psi). After it has turned itself off, within about 5 minutes I hear the circuit breaker trip (It was not even trying to pull a load). Mind you this circuit breaker has only 1 electric line going to the outlet. Why does it do this?
Could it be a weak/bad circuit breaker? or could my compressor be trying for more than 20 amps?
I use it on my 20 amp service in my house with an extension cord and it does just fine.
-BWP
-BWP
