Why does welding cart put welder at an angle.
PoorOwner
CA
As the title say. Does anyone know the reason why some carts are designed that way?
92GreenYJ
San Diego, CA
Better viewing, pushing angle for the controls. Was just using mine earlier to weld the exhaust back on the Charger. Would be kind of a hassle to have to bend over and see the settings if it was level.
CNGsaves
KS and OK
^ ^ ^ Seriously now . . . . . this.
Also better angle for wire feed to spool out and not get kinked.
MikeF2316
Thornhill, ON
It also helps stop it from bouncing off the cart if it's not strapped down.
joe_padavano
Northern VA
electrons go faster if downhill
But the torch comes out uphill...
WWShop
MN
Like others have said, a viewing issue. At least, thats what I always thought.
kwschumm
Olympia, WA
Angle mounting provides for the proper orientation of transformer coils in relation to the earths magnetic field to minimize phase cancellation.
P
PoorOwner
CA
Where is my welder in this picture ?
Does it matter if my welder is inverter based?
Blazinzuk
Afton Wy
In the beginning the welding cart front was built in America where we use the standard measurement system. The back was built in Europe where the metric system rules. The numbers were the same the distance was not.
Unfortunately somewhere in the history of welding cart production the original plans were lost. All they had were bicontinent welding carts. Copies were made. Assuming no mistakes had ever been made, a mistake became the correct way.
And that my friends is why welding carts are tilted .
gol4
Nebraska
I bet if you look you will find the cart was made in China and the welder the good old USA.
If you set a HF welder on that same cart it will appear to be level.
Nothing out of China works like it should.
tarmy
Nor Cal
Winner....this and that is why you always need a permit. This wouldn't happen if the proper government inspection was performed. Besides...there are fees involved...and clearly they haven't been paid or this travesty would have been prevented.
The idiots and ingenuity on this site still amazes me....
BD1
north side
Agree on seeing controls and since many welds are done on a bench or table , the MIG gun will be used above bench height. The cable at the machine will have a longer sweep with machine on angle. This will allow wire to feed easier then a TIGHTER 90 bend.
BD1
north side
'' Besides, it's not the size of the bottle, it's how you use it.''
Yep, that's what she said '' :lol_hitti
whateg01
doo dah, kansas, usa
My welding cart puts the MIG up at about chest level and is level. The TIG lives under that, and can be level or angled. It's on a pivot. I'm not worried about it tipping with two 125 cf bottles on the back of the cart. The cart I made for Dad was made so the welder could be angled however it worked best. So when working under the car, it could tilt down. A lip on front and back keeps it from sliding off.
Dave
mikegt4
sw ohio
My welder sits flat on it's factory (Hobart) cart. It means that I have to get down on my knees and tilt my head back to get my glasses to adjust to where I can read the controls. It would have been better to tilt the welder.
