Why is my plumbing work all corroded and rusty???
Chevy-SS
Rhode Island
Five years ago, I plumbed in a new 3/4" copper supply line for my well water. I 'thought' I did a pretty good job, sweating in all the fittings. It looked beautiful at the time. But now it looks like **** (see pic below). There is corrosion at all my sweat joints, and it's even rusting at the hanger too, jeesh. This area of my basement is pretty dry, with my hot-air furnace very close, but the basement is big and I do have two sump pumps collecting water, so there is humidity in the air.
I have 4 questions:
1) What's causing all this corrosion?
2) Is there any danger of leakage?
3) How can I prevent this in future work?
4) Can I fix this?
Many thanks, Dave F.
SlappyWhite
Upper Canada
My guess is it is from flux left behind after sweating the connections. It is an acid, and any residue should be removed after the work is done IMO (I just wipe down with a wet rag after making the connection). Not a big short term leakage risk IMO, but others may have more info on this.
As for the hanger, is it steel, looks like iron oxide not copper oxide in the pic? If so, no bueno with copper... If it is steel this is where leakage may be a future problem.
ericlar80
California
Yep, green corrosion is where you had flux that was not cleaned off properly, and the red oxide is the steel galvanically reacting with the copper pipe.
The flux contamination can lead to pinhole leaks, so best to get that corrected soon (just clean it off with scrub-brush, then salt & vinegar water mix, and them soapy water.
The steel part should be replaced with a copper strap that wraps around the pipe and is then nailed into the joist.
MJO
Did you use dielectrics where needed? The copper pipe touching any other than copper or brass? Wife using the pipe to hang coat hangers? Isolate the copper from dissimilar metals.
dogdog
white powdery stuff is either lead or aluminum I think... Green is copper, red is iron. From the trails of it, it does look like those flux paste corroding the solders..
PelicanPines
And yes... it is my experience... you may get pin hole leaks.
1. replace that hanger with a copper or plastic one.
2. Clean things up...
If you get a leak because you clean it... it would have leaked anyway in time.
In the future ... as mentioned. Clean off the flux...
stokefire7
The green is left over flux. The white is calcium, I think. Here's a pic from some pipe that was in my house before I ripped it out. You can see the rust on the gas line below. There's a little spot of white on that swing joint above it.
stokefire7
You'll have to show me your joint prep and the products you're using for an opinion. I've been in the pipe trades for thirty years, I can help.
danski0224
Near Naperville, IL
The white stuff is most likely a residue from flux.
The distribution is fairly consistent. A leak would be more apt to be concentrated in one spot.
The white corrosion also follows gravity, like where condensation collects on the pipe, shown by the offset down.
The copper plated pipe hanger is rusty due to moisture. Those types of hangers are pretty common, and yours looks like it is the coated/painted type- not copper plated. Good luck finding actual copper pipe hangers at a hardware store. There shouldn't be an electrical current from the wood to the copper... dielectric corrosion should be able to be safely ruled out.
You mention well supply piping, so the pipe is condensating.
Brush off the white stuff, clean the residue, and put some Armaflex on the cold water supply to prevent condensation.
C
Chevy-SS
Rhode Island
Yeah, thanks gents. :) It appeared to be flux contamination, as it mostly cleaned off and looks halfway decent now. The strap is a POS Home Depot item.
Be aware many straps that look copper, are only copper plated steel.
Check w magnet at store.
Marc
Thanks, the cleaning helped. Plus I will get new straps, either copper or plastic. No more Home Depot POS straps!
Thanks, good tips. I might try some of the Armaflex. Thanks again....:thumbup:
ericlar80
California
He also didn't care to protect the wood from getting burned while sweating the lines... :shocking:
dogdog
What's the brown ?
LOL... Brown is the Happening :)
But seriously, brown on those thread looks like dried out sealant paste mixed with some light rust... I have that on bronze to iron joints...
stokefire7
The brown joke went right over my head. LOL :dunno:
I dunno bro, shouldn't be any rust as it's all stainless and copper on potable water. Dope is Megaloc. Outlet doesn't show a "leak".
stokefire7
You can get mild corrosion between stainless steel and low grade brass. So, it could be that mixed with some pipe dope.
I thought it might be from the glycol color but that doesn't work on the potable side. Our water supply is mountain runoff , cold and hard.
I'm assuming it's iron in the water. I'll check on that.
I do have a brass ****** on the recirc nozzle to a lead free B. V. with a galy plug, no leak.
stokefire7
...a quick pic of corrosion on a back flow preventer discharge from sulfuric acid fumes .
dogdog
This is the chart I remember I looked up when I used those stainless bolts for exhaust and it gal up so bad, that I had to cut it off ...
http://www.simpletwig.com/blog/galvanic-action-corrosion-prevention/
***I actually got lazy, the original chart was from bolt depot or something.
again , I don't have exp with stainless stuff too much on water stuff. was just joking about brown :)
metlmunchr
The OP's corrosion at the joints is a classic result of using an aggressive self cleaning flux and not thoroughly cleaning the joint afterward. Any flux that's aggressive enough to eat away the surface of the copper without cleaning with sandpaper and fitting brushes prior to soldering will give the same result. All of these fluxes have free hydrochloric acid in the mix as the self cleaning agent.
Mechanically cleaning the tubing and fittings followed by the use of a mild flux like Nokorode standard paste as marketed by Rectorseal will prevent such problems even if you don't clean the excess paste off the joint after sweating.
FWIW, the specs in the great majority of commercial plan and spec construction work specifically prohibit the use of self cleaning flux on copper piping, and the OP's pics show the reason why that's the case.
C
Chevy-SS
Rhode Island
OP here.... interesting read. You could be right.
Thanks for the tips.................................
:thumbup:
stokefire7
...still haven't said what products you're using. One suspicion I have is leaded solder.
andyvh1959
Green Bay WI
This all reminds me of the Lennox HM30 Complete Heat furnace/hot water heater I had in my house when I bought it back in 2002. When first in I thought, "Lennox, good quality product, excellent!" NOT so, what a piece of **** and trouble. 1st winter (Green Bay) the furnace AND hot water shut down, doe to a leak and pressure loss. In the HM30, hot water pumped through the A-coil is the heat source for forced air blown through the coil. Novel idea, maybe for an RV. NOT for a house. In 2002 that HM30 was already 10+ years old, and a weld failed on the stainless steel water tank. Service guy from local Lennox diagnosed it, said the tank had to be replaced, but they had a tank in stock. Wait? What? You have a S/S tank in stock for a ten year old furnace? Oh ****.
It went on like that every winter. This system was loaded with corrosion everywhere, copper, brass, aluminum, steel certainly, but everything had corrosion of some sort which I thought was largely electrolysis. At the five year point, the older technician this time, when I asked him what he'd do if it was his furnace, this guy with Lennox on his shirt, quietly said with a slight smile "I'd get rid of it NOW!"
Lennox did step up, gave me a $1500 credit for the HM30 to buy a new Lennox gas/FA system and separate hot water heater, gave me a reduced price on the system, along with the tax deduction for the system, my installed cost out of pocket was only $2500. No troubles since then almost ten years now, my faith in Lennox was restored.
